How Expensive Can a Tranny Swap be?? Auto To 5spd
Old May 17, 2013 | 09:27 AM
svillegas2253's Avatar
hey I recently started working on my 96 maxima after a while of no use. Looking to swap the old auto transmission with a 5speed manual. Any ideas of what it might cost? Thanks
Old May 17, 2013 | 09:33 AM
Amerikaner83's Avatar
doing it yourself...cost of parts, 500 bucks or so if that.
Getting it done at a shop...triple that, at least.
Search around for all the aprts you'd need and then makeyour decision
Old May 17, 2013 | 09:58 AM
Yea that's what I was guessing, I'm doing all this myself so I don't think it should cost me THAT much. Thanks man
Old May 17, 2013 | 10:00 AM
The 5 spd in our 4th gens is actually weaker than the auto...the Input Shafts go out...perhaps you should look at doing a 6 spd swap instead?
Old May 17, 2013 | 10:09 AM
Really, didn't know that. Ill look into that swap instead, by any chance do you know what model # that tranny goes by?
Old May 17, 2013 | 10:53 AM
Quickywd01's Avatar
http://forums.maxima.org/all-motor/3...edure-faq.html Hopefully my 6 speed swap will be about $700. I can do your's for $3200 parts included.
Old May 17, 2013 | 12:39 PM
Well I'm doing all this myself as a project, but thanks for all the info very helpfull. I guess now I have to work on gathering all the right parts
Old May 18, 2013 | 12:06 PM
CallMeThatOneGuy's Avatar
I'm keeping my auto since they're sssoooo common and handle more power.. lol maybe you want a shift kit instead? Or the drop resistor mod....
Old May 18, 2013 | 02:25 PM
ShocknAwe's Avatar
Or just modify your 4AT and rape any M/T out there in the 1/4m
Old May 18, 2013 | 07:49 PM
Nealoc187's Avatar
SLOW
yeah let me know how that works out
Old May 19, 2013 | 12:53 AM
You must have never been in a modded 4at.. how common is an i30? 4at lsd swap? super cheap and common compared to a 5spd i30.. shift kit? not too pricey. Drop resistor mod? about $10. And then you have perfect shifts that slam into gear faster and stronger every time in an overall stronger transmission. It may seem like a little less fun, but it's fun in a different way. Plus it just makes sense for functionality, cost efficiency, and retaining that sleeper-status.
Old May 19, 2013 | 05:04 AM
Max_Gator's Avatar
What about that rape part?
Old May 19, 2013 | 05:18 AM
Max_Gator's Avatar
No way now how $500.
You can't find a decent trans alone for less than 600 or 700. Plus you will probably have to ship it. So, I'd figure 700-800. $800 was the best I could do when I replaced my 5spd last month.
Then you've got: decent clutch - $300; flywheel $ 200-600, axles $200 unless you use crap rebuilt, shift mechanism ???, other misc parts.
If you got lucky at the junkyard or on here and got a used flywheel, shifter mechanism and axles, great deal on the trans, use crappy clutch (which is the one thing I wouldn't skimp on) . . . maybe you get it done for $1000.
I think you will find yourself closer to $1500 than $1000.
Edit: I forgot that you should be able to get something for your auto trans and parts. So, I would say around $1000.
Old May 19, 2013 | 03:31 PM
Max streets's Avatar
theirs member on here selling the 5spd swap for 800 bucks his name is thetorp ask him if he still got it.
Old May 20, 2013 | 08:05 AM
Max_Gator's Avatar
Here is the link.
http://forums.maxima.org/4th-generat...wap-850-a.html
That appears to me to be a clutch with 145k miles on it. Not a new one. It would make no sense whatsoever to throw the used clutch back in there. Unless you like dropping the trans yourself. I've done mine several times and it just isn't fun.
So, even if he's still got it and you could make a deal, you need to factor in the cost of a new clutch. And probably a resurface of the flywheel. (Yeah I know ours are dual mass and shouldn't be resurfaced. I've never had a problem and mine has been done twice.)
Old May 25, 2013 | 05:03 PM
Nealoc187's Avatar
SLOW
a modded maxima 4at doesn't shift faster than i do, and it doesn't get down the track faster either (except for jime's heavily modded, stripped out, nitroused 3.5 barely streetable exception).
i will agree with you though that *properly* modded it can handle more power than a stock 5spd can, but that doesn't come into play until you're looking at north of 350ish lb-ft of torque for the most part.
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
I<3 A32's
Sep 10, 2015 11:07 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
