1995 Maxima Auto - Shift suddenly "stiff" to move into Drive.
Old May 17, 2013 | 07:10 PM
stromm's Avatar
I did look cause I think I remember a post, but I can't find it.
About a week ago, the shifter got "stiff" going into Drive. Like something is binding. It's fine going back into Neutral, Reverse and Park (even between those three).
So I'm wondering what might be wrong.
Next does anyone know of a write up on disassembling the center console?
Thanks all!
Old May 17, 2013 | 07:52 PM
max ride 41's Avatar
its easy dude, you just need a regular flathead screwdriver and you just pop the top section out first. and then the middle pops up and you may just need to clean the linkage to your shift lock celenoid. its a little tan box that releases the shifter after you depress the brake. or it might be time to replace it. same thing happened to me twice, both times i spilled a sticky drink into my center shifter and it started sticking and i cleaned it out the second time and its been fine. you may want to find out what to spray in there to clean, and you going to want to re-spray the linkage after thats done with some very light lubricant. ask a tech or call the dealer and ask what you should use. btw, the dealer around here cleans and repairs that for around 40.00.
Old May 17, 2013 | 10:43 PM
svillegas2253's Avatar
Yea just get in there and clean the shift lock celenoid. Mine also kept getting stuck one day, probably all the spilled drinks.
Old Sep 29, 2019 | 02:42 PM
emjee's Avatar
This just started happening to me. How can I tell if the solenoid needs to be replaced? I cant see any dirt or guck around it
Old Sep 29, 2019 | 04:01 PM
stromm's Avatar
Hopefully someone else can help.
I sold my Maxima before I got a chance to look into my rarely happening problem.
Old Sep 29, 2019 | 05:15 PM
well, depends on how old the car is and the miles. plus, have you ever spilled any drinks on the shifter face? if so, that's easily cleanable with some cleaner and a rag. you basically have to take center dash pieces off to expose shift solenoid and clean the wire to the shifter. took me 40 minutes after watching a video on you tube.
doug1c
Jul 30, 2012 06:36 PM
dineth00i30
36
Oct 28, 2008 02:39 PM
zourtney
Aug 8, 2008 08:52 AM
MaximaGuy719
Jul 4, 2003 02:12 PM
GoGrowAFro
Apr 3, 2003 08:22 AM
