cefiro headlights on 4th gen
Old May 20, 2013 | 07:51 PM
TurboA32's Avatar
I've searched for a how to on the cefiro headlights on a 4th gen and there was nothing useful. The redlinemax link doesn't work and is there anyone who installed these headlights on a 4th gen and has a good write up with pics?
Old May 20, 2013 | 08:22 PM
WendysMaxima's Avatar
I just pass on the new headlights and went with new bulbs. If you're having that much trouble, I'd just go with OEM headlights. ddmtuning has good deals on HID kits that aren't that costly. Got mine with ballasts, brackets and bulbs for around 90$. Easy install too.
Old May 20, 2013 | 08:43 PM
rayrobot's Avatar
http://www.vqpower.com/v3/content/a3...nissan-maximas
maxprivate's Avatar
Black Lion
You are better off going with R34s and retro projectors into the housing, this will give you the best light output possible and the headlights are a much better fit than the Cefiros. Ask around and you will see my words to be true.
Old May 20, 2013 | 09:10 PM
rayrobot's Avatar
mhmm, or you can just retrofit your own oem headlights.
TurboA32's Avatar
Thank you
Old May 21, 2013 | 03:07 PM
litch's Avatar
ah sir.
I believe I can help.
I had ceffy headlights on my 4th gen
also here are some close ups of the ceffy lights uninstalled.
I have an extra set that I don't need anymore, so if you want to give em a try, I could help you out, pm me if you want the set. they just sittin around, my max is retired and these were "just in case" headlights since its a bish to get them...
the headlights on my max now are just clears,
note how there is no black gap between the headlight and the corner,
on the jdm headlights they have that black "divider"
just follow that install instruction if you wanna give it a shot.
Old May 21, 2013 | 03:55 PM
Dj M's Avatar
4x better clean
I recently ordered the r34 headlights, do you know what would be the hid conversion? since is two bulbs now with the one piece, and would the new conversion be any issue since the number is changing?
Old May 21, 2013 | 04:18 PM
Amerikaner83's Avatar
search around...it would be a HUGE difference in bulb number and all that...look for posts by "Chrisman287" specifically
MAXSE5SPD
Sep 17, 2022 04:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
Lowered_a33
Sep 1, 2015 07:49 PM
