Horrific idle!
Old Jun 1, 2013 | 12:36 PM
Brandon8965's Avatar
Horrific idle!
I replaced my rear valve cover gasket as well as all the spark plugs.
When I put everything back together and cranked the car it idles insanely bad. When I press the throttle it revs smoothly but returns back to this awful idle.
I don't understand what could be wrong as the car was running perfectly fine before I took everything apart.
Please help!
Old Jun 1, 2013 | 01:13 PM
EvoTillIDie's Avatar
did you tighten them down 2x to the right spec each?
Old Jun 1, 2013 | 03:00 PM
asand1's Avatar
You have a vacuum leak now. Check all the lines you disconnected including the PCV. If you removed the throttle body from the intake, did you replace the gasket?
Old Jun 1, 2013 | 04:03 PM
I definitely tightened them down correctly.
i did replace the throttle body gasket as well as the egr gasket.. but i will have to go back through and connect everything again to make sure i didn't miss anything but this is very strange
Old Jun 1, 2013 | 09:44 PM
bprice92's Avatar
This may be unrelated but after replacing both valve covers and the intake plenum gasket my engine was running rough. I proceeded to add motor oil while the engine was running and it smoothed out.
My thought was that because I had left the rear cover and plenum off overnight and thoroughly cleaned them both that the added oil helped to re-lubricate them.
Like I said, it may be totally unrelated and I could have been low on oil anyways but I can say for sure this is what smoothed out my roughness after the repairs.
Old Jun 1, 2013 | 10:42 PM
PowerTotheMax's Avatar
Did you replace the UIM gasket?
Old Jun 1, 2013 | 10:59 PM
figueroa81's Avatar
before you do anything check the 2 small vacuum lines 1 goes to the tb on the bottom ( also some tb have 2 inlets tubes if your do make sure that one is connected & the other is plug) & the other goes to the intake manifold if they come off that may be your problem
Old Jun 2, 2013 | 05:57 AM
njmaxseltd's Avatar
Describe what you feel Horific applies to?
Missing, hunting, to high, to low?
Kind of difficult to trouble shoot on the word Horific over the Internet...
Old Jun 2, 2013 | 10:28 AM
it sounds like an old chevy.. but it will not rev past 2200 rpm
i'll post a video when i get off work at around 4
Old Jun 2, 2013 | 12:20 PM
maxfever1987's Avatar
Did u connect the maf plug in?
Old Jun 2, 2013 | 12:24 PM
yes sir it is
Old Jun 2, 2013 | 12:25 PM
Originally Posted by Brandon8965
yes sir it is
Check the connection again, no rev above 2200 rpm is usually a maf prob.
Old Jun 2, 2013 | 05:48 PM
This is what it sounds like...
http://i206.photobucket.com/albums/b...ps4fba4414.mp4
TKHanson
Nov 24, 2018 01:39 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
