Back Fire at Start
Old Jun 6, 2013 | 02:23 PM
97maxima1981's Avatar
Back Fire at Start
After I cleaned my clogged EGR tube and IAC, my Maxima is backfiring, out of the exhaust, at initial ignition. It did not do this when the EGR was clogged, and I have double checked all of the vacuum lines around the area where I worked. I am lost as to what is causing this, can anyone help?
Old Jun 6, 2013 | 03:26 PM
njmaxseltd's Avatar
A back fire in the exhaust is caused by raw fuel in the exhaust system being ignited by hot exhaust gases. Does this happen on a cold start? Are you sure it's not an intake pop, possibly caused by the EGR hanging open?
Old Jun 6, 2013 | 09:21 PM
It happens with every start, cold or hot. I guess it could be popping in the intake, but I can hear it coming from the exhaust when it pops (while standing by the exhaust pipe). Would the EGR sticking open cause these symptoms? Because like I said in the first post, it did not do this until I cleaned the EGR tube.
Old Jun 7, 2013 | 05:42 AM
njmaxseltd's Avatar
Go back over your work, something isn't right.
Old Jun 7, 2013 | 06:30 AM
I have, more than once. There was only a couple of things that had to be removed to clean the tube. Everything is tight and sealed.
Old Jun 7, 2013 | 12:06 PM
I just realized that if I press the gas pedal and get the RPMs up to 4k or so, it makes the same sound out of the exhaust.
JRod28
Dec 29, 2023 09:56 PM
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
kirkhilles
Aug 8, 2015 10:53 AM
