Questions about KYB AGX
Old Jan 14, 2002 | 02:15 PM
GTRBlkMax97's Avatar
I am too lazy to search, BTW
but they are adjustable how, I know its the bound and rebound but what exactly does it do, I feel like a dumbaus asking but oh well
Old Jan 14, 2002 | 02:22 PM
Bags's Avatar
VG Ridah's Biatch Hoe
but they are adjustable how?
You turn a **** or screw and they adjust
Old Jan 14, 2002 | 02:24 PM
gtr_rider's Avatar
192.168.1.1
Old Jan 14, 2002 | 02:27 PM
ok I meant what does setting the bound and rebound, low, is that stiffing it up or what?
Old Jan 14, 2002 | 02:28 PM
gtr_rider's Avatar
192.168.1.1
setting that I think stiffens up the rebound of the suspension when you hit a bump.
Old Jan 14, 2002 | 02:31 PM
Bags's Avatar
yes you can change how stiff each shock or strut is. thus making the bound and rebound change
Old Jan 14, 2002 | 02:34 PM
what exactly is bound and rebound, the movement of the struts themselfs like how far up and down they move?
Old Jan 14, 2002 | 02:35 PM
gtr_rider's Avatar
192.168.1.1
yes that is exactly it.
Old Jan 14, 2002 | 02:38 PM
so what's the best?
Old Jan 14, 2002 | 02:45 PM
SpeedFrk38's Avatar
so what's the best?
there is no best. it's all driver's preference. i had mine set on 2 in the front and 4 in the back originally but after a few weeks of driving, that setup was too stiff.
i now run 2 in the front and 2 in the rear. kyb agx shocks come with 4 settings for the front shocks and 8 settings in the rear. 1 in the front and rear would be the softest setting equating a comfortable ride. 4 in the front and 8 in the rear would induce a bone-jarring, tooth-chipping ride that would shake your bladder and colon loose of all contents.
hope this helps.
Bags's Avatar
depends on what your doing? what the road surface is like? how fast are you going? are you turing or straight line?
Old Jan 14, 2002 | 03:39 PM
KWheelzSB's Avatar
Dampers, aka, Shocks, aka Struts - Explained.
http://www.findarticles.com/cf_dls/m...l?term=damping
VERY comprehensive. Hope it helps though. . .
The terms you're looking for are "rebound" and "compression" dampening.
These terms refer to how the shock/strut controls the forces created when the spring compresses (as when you hit a bump) and when it rebounds (when the compressed spring's energy causes it to "push-back" & return to it's original length)
Old Jan 14, 2002 | 03:55 PM
Micah95GLE's Avatar
It's not called "bound" and rebound. The term is compression and rebound.
Old Jan 14, 2002 | 04:13 PM
Bags's Avatar
www.howstuffworks.com
start there or where KWheelzSB pointed you
Unclejunebug
Apr 2, 2016 05:42 AM
maxima-junky
Oct 7, 2015 06:13 PM
Socalstillen
Sep 26, 2015 12:01 PM
