Can these be a solution to equal length y-pipe?
Old Jun 12, 2013 | 08:41 PM
kajeno's Avatar
Walker 54521 Y Pipe | eBay
Maxima Infinity Y Flex Joint Pipe with Gaskets 3A1474 2002 5Y700 54521 | eBay
Engine Y Flex Pipe Gaskets 06 2001 12 2002 Maxima I35 3 5L New w Warranty | eBay
Old Jun 12, 2013 | 09:06 PM
ShocknAwe's Avatar
no that is not the Y-pipe you would receive anyways
Old Jun 12, 2013 | 10:11 PM
DennisMik's Avatar
Here is a a photo of the Warpspeed y-pipe for a federal emissions Maxima. All brands will look very similiar.
Do you know if your car is federal or cali emissions?
Old Jun 13, 2013 | 07:32 AM
Amerikaner83's Avatar
OP supposedly has a 97 SE, so it's FED
Old Jun 13, 2013 | 01:54 PM
DennisMik's Avatar
Nissan didn't make Cali SE? That's interesting.
Old Jun 13, 2013 | 02:27 PM
aackshun's Avatar
SE's come in all shapes sizes and years.
Cali Specs come in all years too.
The only year that matters for the cali spec cars are the 99 Cali Specs.
So you can have a 98 SE Cali spec, and use the Y-pipe in the image above, but oh gawd, not the 99 Cali Spec...
Old Jun 14, 2013 | 05:57 AM
carsnwomen91's Avatar
they all look to be for 3.5L's. it would fit on a 4th gen except you might need to grind the crossmember like with obx v2's and extend the front pipe up to the header
why not?
Old Jun 14, 2013 | 11:07 AM
dwapenyi's Avatar
Mine's a 98 Cali...and that's the truth right there.
Old Jun 14, 2013 | 05:05 PM
RA030726's Avatar
I'm nutty for Nissans
The 5th gen Y pipe looks like a 99 Cali. There is a cat in the rear down pipe and just a straight pipe that goes to the front pre cat. No aftermarket unit will have equal pipes and no cats.
The 5.5 gen Y pipes shown won't bolt up to the 4th gen manifolds. You could make a small intermediate pipe, but those aftermarket Y pipes wont flow any better than a stock 5.5 gen Y. The cats are not in the Y on the 3.5.
Old Jun 16, 2013 | 08:37 PM
kajeno's Avatar
post no 7 & 9
this is the discussion I was looking for regarding the 5.5gen fitting on the 4gen. Now are the only fabrications needed extensions to the headers?
Old Jun 16, 2013 | 09:25 PM
aackshun's Avatar
Originally Posted by JSutter
The 2000 Cali Spec and 2001 Y pipe looks is a 99 Cali. There is a cat in the rear down pipe and just a straight pipe that goes to the front pre cat. No aftermarket unit will have equal pipes and no cats.
The 5.5 gen Y pipes shown won't bolt up to the 4th gen manifolds. You could make a small intermediate pipe, but those aftermarket Y pipes wont flow any better than a stock 5.5 gen Y. The cats are not in the Y on the 3.5... Matter fact they are essentially the same as the aforementioned situation above
Fixed.
Eh wah?!
Old Jun 16, 2013 | 10:53 PM
CallMeThatOneGuy's Avatar
Fixed.
Eh wah?!
But.. But... Why will it not fit? Crossmember? I understood that the 3.5 and 3.0 were about the same size and the piping was very very similar from the engine to the main cat
Quickywd01
Sep 21, 2016 09:36 PM
jchronis2552
Sep 21, 2015 05:52 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
lrb6805
Sep 17, 2015 04:49 PM
