95 max tickimg under hood drains battery
Old Jun 22, 2013 | 11:39 PM
Aaron Michael Farland's Avatar
I've had a ticking noise under the hood with engine off since I did a motor swap. When I pull the ECCS fuse under the hood by the battery it stops. What does this fuse fully control? I've tried the relays near the interior fuse panel and no luck there. Hope to follow and figure it out. Any ideas?
Old Jun 23, 2013 | 11:10 AM
maxinout93's Avatar
ive also had a ticking noise that was coming from the iac valve, but only when i turn the car on, but after removing the iac and changing some fuses the noise is gone now.
Old Jun 23, 2013 | 11:16 AM
CallMeThatOneGuy's Avatar
How loud is the ticking?
Old Jun 23, 2013 | 11:03 PM
Sounds like a clock. Sounds like its ontop of the air intake...
Old Jun 23, 2013 | 11:39 PM
If I were you, I would start taking stuff off and unplugging things until it goes away. Then work from there.
Old Jun 24, 2013 | 05:00 AM
Trini Boom's Avatar
Must be IACV making noise. Unplug big harness from IACV and see if it stops.
Old Jun 26, 2013 | 02:44 PM
It seems like that's it. So is it bad then? Of I replace it would it just continue?
Old Jun 27, 2013 | 03:47 PM
So I replaced it with a used and the ticking is even worse. Is there a relay? The fuse ECCS disables a few things and one is the iac. (It stops ticking when ECCS fuse is pulled and car also won't start.
Old Jun 28, 2013 | 11:28 AM
maxinout93's Avatar
yah i think i pulled my eccs fuse and replaced it, also pulled iac valve due to removing the intake manifold, the noise just went away.
Old Jul 11, 2013 | 03:56 PM
But the fuse wasn't popped. Just a small amp fuse. Is there a separate relay?
sctludwig
Sep 1, 2022 01:32 PM
97_GXE
20
Sep 17, 2015 08:12 PM
markevans999
Sep 10, 2015 04:29 PM
Hdnseek
Sep 9, 2015 05:55 AM
