Replacing water pump which tensioner do I ask for at Nissan?
Old Jun 29, 2013 | 06:35 PM
porshapower928's Avatar
How many tensioners are there? Which tensioner do I ask for at Nissan. I figure since I will be replacing the water pump I should replace the tensioner as well. Thank You in advance!!
Old Jun 29, 2013 | 07:04 PM
maxgtr2000's Avatar
KH3 by popular demand
If your car is not a 95 or 96 you probably don't need a new tensioner. It is spring loaded.
Old Jun 30, 2013 | 04:43 PM
Thank You for the reply. My car is a 95..... How does the tensioner work if not spring loaded? Thanks again.
Old Jul 2, 2013 | 12:49 PM
svezarov's Avatar
They are all spring loaded, but in 97 or so they changed the shape of it. Problem is that if you buy the new one you will not be able to install it, since the chain guide is also different, so stick with the existing one. I did that and no problems for 2 years so far. If you decide to go new, buy the chain guides and open the chain cover and change them too.
Old Jul 2, 2013 | 10:39 PM
Trini Boom's Avatar
Depending on the mileage you have, the tensioner and guide may have already been replaced with the updated one. Does your timing cover look as if someone opened it before and sealed it back and silicone is sticking up? If so, remove tensioner from access door and post pic so we can tell you if it is old or newer tensioner.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
