1997 Maxima Feed wire problem help
Old Jul 4, 2013 | 08:03 AM
OniisanMaxima's Avatar
the small wire going to the starter {feed wire} has no current going to it what could be the problem
Old Jul 4, 2013 | 08:36 AM
asand1's Avatar
Alot of things. Manual or auto?
Old Jul 4, 2013 | 08:54 AM
DennisMik's Avatar
Yes, several things. Most common is the ignition switch going bad.
What happens in a working car is that the ignition key causes a relay to energize and the relay sends power to the starter solenoid via what you are calling the "feed wire" and the starter spins.
If the ignition switch is ok, then you could have a broken wire going to the relay, a bad relay or a broken wire between the relay and the starter. Once again, the ignition switch is the most likely problem.
Old Jul 4, 2013 | 12:43 PM
asand1's Avatar
Park neutral safety switch. Clutch inhibitor switch.
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
bassmann
Aug 3, 2015 07:53 PM
