BATTERY CHECK- RELAY STUCK-pls help
Old Jan 15, 2002 | 06:20 AM
jayanth's Avatar
The battery check light is on as the relay is stuck...It sometimes releases and the light goes off..
Please tell me where to find it and how to replace it?
as always TIA,
jay
Old Jan 15, 2002 | 06:55 AM
95emeraldgxe's Avatar
are u talkin about something on the fuse box???? can u be more specific??
Old Jan 15, 2002 | 06:59 AM
jayanth's Avatar
The car has a relay which engages or snaps into position when the key is turned on and as soon as the car is started it should go off, mine is always engaged even though the key is removed, the relay is stuck
hope this is clear.....
Old Jan 15, 2002 | 07:31 AM
njmaxseltd's Avatar
hope this is clear
Are you sure it's stuck? Perhaps it's alerting you to a problem which is what it's supposed to do. Have your charging system checked out.
Old Jan 15, 2002 | 07:47 AM
jiaxima96's Avatar
But he mentioned "...even though the key is removed....". I'm not sure if the warning light should still stay on with the key out.
Old Jan 15, 2002 | 07:53 AM
njmaxseltd's Avatar
Good point, but how does he know it's still engauged? Is the light on when the key is off or out of the car?
Old Jan 15, 2002 | 10:47 AM
jayanth's Avatar
the light is on always key or no key , I checked the battery it's OK ..i am pretty sure it's the relay should get hold of Haynes or finally go to Covenant... i don't want to go there
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
zmcneely13
Sep 26, 2015 02:26 PM
