A/c compressor replacement
Old Jul 14, 2013 | 03:33 PM
Macksima2's Avatar
95 GXE auto,ac doesnt work was told its my compressor want to try nd replace it myself i have haynes manual nd a 40pc socket set. wondering if u have any tips on how to replace it. nd i also heard u need to replace ac evaporator as well bcuz it will get ruined from being exposed,is that true?
Old Jul 14, 2013 | 08:46 PM
bprice92's Avatar
I haven't done the job myself but my tip would be to download the factory service manual to use as your primary guide and to use the Haynes as your secondary. I own both and always use or check the FSM first because it's more thorough and better yet, it's free!
Download 1995 FSM below:
http://boredmder.com/FSMs/Nissan/Maxima/1995/
Old Jul 15, 2013 | 05:11 AM
njmaxseltd's Avatar
Please do not expel the refrigerant into the air, it's not good for our environment.
What was the issue with the system that pointed to a faulty compressor?
Old Jul 15, 2013 | 07:02 AM
pflicht's Avatar
[QUOTE="kevinoseguera99;8822674"] You're not suppose to release out into the air, but its not a huge deal./QUOTE]
Release the refrigerant in front of a cop and come back and tell me how its not a huge deal. Its a federal offense to do so.
sent from HTC DNA using Maxima.org app
Old Jul 15, 2013 | 06:46 PM
kevinoseguera99's Avatar
i was trying to help, you're on your own.
Old Jul 16, 2013 | 06:48 PM
2brosgixxer's Avatar
Not sure what this is referring to so I'll chime in to help the OP.
4 bolts hold the compressor in. AFTER you have the system evaced the proper way, the 2 ac lines are held in by 12mm nuts/bolts. The compressor is held in by 4 14mm bolts. Provided you can loosen the 4 bolts, easy replacement. I could not get mine loose so I paid a shop so I didn't have to worry about snapping them. You also want to note how much Pag Oil is in the OLD compressor after the evac and put that much in the new one. You do not need to replace the evaporator...you need the replace the Accumulator/Drier any time you open up the system. You also need to replace the O-Rings where the lines go into the compressor.
See this link from PMOHR for how to replace the Compressor.
Old Jul 17, 2013 | 03:35 PM
Cebby's Avatar
Timely thread - my A/C compressor sounds like the bearings are going (158k miles).
I replaced everything but my compressor on my Jeep's AC System and echo the sentiments about not releasing the freon into the environment.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
