Brake Pads
Brake Pads
What are some pretty good brake pads? I don't feel like spending $80 for the oem, but if that my last resort then i'll get them. I can get Raybesto pads with a 20% dicount. Are Raybestos pretty good?How long will they last? is there any noise when installed correctly? Should i invest in some anti squeal shims??? How do the Raybestos compare to oem????
Sorry so long....
Chris
Sorry so long....
Chris
Get Porterfields (R4S) or Hawks (HPS) if you don't mind dust and want your car to stop on a dime. There are more agressive pads from each of those but they get less streetable as you go higher up the brake pad ladder.
I installed raybesto quiet stop last friday, they're awsome after breakin, havne't really test it yet becuase my tires are completely gone & when I slam on the brakes abs just turns on...
sorry about thsi spam but can someone help me now!!!! please! I'm buying tires in like 2 hrs
http://forums.maxima.org/showthread....threadid=91445 read the last message there.
Re: Brake Pads
Raybestos QuietStop (ceramix) pads are to me by far the best pads I have ever owned. I had a shop put in some pads and shortly a few months later they squealed like crazy and left tons of brake dust on my rotors. Replaced them with the QuietStop and I am in heaven. No squeals, very little (I mean very little) brake dust and excellent stopping power. They ran me $54.00/set but they are worth every dime.
Re: Re: Brake Pads
If you can get the discount, I say get the Quiet Stops from Raybestos...I installed those on my back brakes and am impressed at the preformance and overall cleanliness of the pads. Definetly a wise choice on my part at the time...worth the money.
your raybestos
I was just wondering --did everyone who used the raybesto pads also install these pads themselves or did you guys go through pepboys? It seems that is the pads that they install for a lot of cars. They are also running a special this week at Pepboys on the Raybesto Quiet Stop pads. I am not sure if the new pads that they install includes turning of the rotors as a part of the package.
I was also wondering, since you guys who have had these pads now for a few months--no complaints? I am looking for new pads that will cut out the squealing (comes with shims right?) and will offer the performance that is just as good as the factory pads.
thanks for your thoughts on this again.
Re: your raybestos
Re: your raybestos
Raybestos Quiet Stop pad are working well for me.
Make sure you get the quiet stops if you go raybestos. I just installed the 19.99 raybestos pads. They are decent FF grade and bonded not riveted. How ever they squeal like almost as bed as my nissan ome pads did. The squeeling under light braking is gone but under moderate braking the queal is there at about 60% of the orriginal volume. I paid 7 for the shims and 99cents for the anti squal compound. I also had my rotors resurfaced. They are very easy to do your self. If you just do the pads there is only one bolt to undo, its the bottom one of the calliper then the pads just pop out. If you call around you can get rotors resurfaced fo between 5-10 each. The rotors just fall off if you undo the bracket that holds the calliper on. ( 2 bolts) Word of caution i found, If your original pads are very worn you will need a c clamp to compress the piston to get the calliper over the new thicker pads. And in the back either a special too or needle nose pliers to turn the ****ton.
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
