Accidentally hooked up the jumper cables backwards, car won't start,no lights on dash
Old Aug 15, 2013 | 02:13 PM
Dbird's Avatar
Accidentally hooked the jumper cables backwards, car won't start, no lights on dash
So I had a lapse of common sense and accidentally hooked up the jumper cables backwards while trying to jumpstart my 1996 Maxima. Since I was in a hurry and the battery was all the way down, I disconnected one of the terminals on the maxima so I could jump it directly with the battery in my tahoe.
Soon as I connected the cables I saw smoke coming from the jumper cables which are now completely fried. I immediately disconnected the cables and tried jumping the car with a different set of good cables,but the car will not start.
I have no lights on the dash and nothing electrical in the car works. Ive checked all the fuses including swapping the fusible link (140 amp main fuse) with no success. All the uses are fine. Could it be a fried ECU? Any help would be appreciated. Thanks in advance
Old Aug 15, 2013 | 02:37 PM
Amerikaner83's Avatar
could it be? yeah it could. is it? I don't know. Double check all fuses and fusible link...ohm out with a meter, don't just look at it either.
Old Aug 15, 2013 | 04:51 PM
asand1's Avatar
You disconnected the maxima prior to jumping? And then you connected the tahoe to the max battery via jumper cables?
The max electrical should be fine.
Or did you connect the jumper cables to the maxima battery cables?
Old Aug 15, 2013 | 05:27 PM
chrome91's Avatar
you might have fried the ECU. make sure you check all of the fuses again, at work once i derped and installed a battery backwards on a Mazda MPV. all that happened was the big main fuse blew, replaced it and all was dandy
Old Aug 15, 2013 | 07:05 PM
jholley's Avatar
Check the 140amp battery fuse link. It's bolted down in the center of the fusible link box next to the battery.
Old Aug 15, 2013 | 07:43 PM
2brosgixxer's Avatar
^^^THIS is a good point. If I understand you, if he unhooked the battery (+) cable then put the (-) jumper directly on the (+) battery terminal, he should not have blown anything fuse wise, right?
Old Aug 15, 2013 | 08:12 PM
He said he reversed the wires which to me means the positive of the truck battery was attached to the car's ground, and the ground from the battery attached to the positive terminal of the maxima battery.
Old Aug 15, 2013 | 09:31 PM
^^^ Just clarified my post with the addition of a (-) that may clear up what I was trying to say.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
Trin1j23
Aug 12, 2015 08:31 PM
kirkhilles
Aug 8, 2015 10:53 AM
