Maxima Won't Start - Electrical
Old Aug 26, 2013 | 04:42 PM
DB206's Avatar
I have a weird tale:
I was on a drivable beach and my 95 Maxima got completely stuck in the sand. The sand was halfway up the wheel wells. Once I tracked someone down to pull me out, the car wouldn't start. I knew it wasn't the battery because the lights didn't dim when I tried to turn it over. So here's what it's doing:
When you go to start it, it will not turn over at all. You hear one click and that's it. I though it was the starter, took the old one out and reinstalled, no dice. I crawled under to see if anything was obviously wrong, I didn't see anything. I ended up popping the clutch to get it started. Now that I'm home I brought a new starter, didn't resolve the issue. I checked all fuses and swapped some of the fusible links that have to do with starting, nothing. I checked the clutch switch by the pedal, bypassed that to see if it was faulty, no. Any ideas as to what it could be??
Thanks,
David
Old Aug 26, 2013 | 05:10 PM
Drag0n97's Avatar
Ck grounds and crank sensors also add a ground from oil pan to bell housing then try to start it
Old Aug 26, 2013 | 09:32 PM
DB206's Avatar
All grounds are fine... I checked.
Old Aug 26, 2013 | 11:12 PM
DennisMik's Avatar
Is the click coming from under the hood (the starter) or under the dash (the ignition relay)?
Check the battery voltage (engine not running). It should be 12.25 - 12.5 volts. Keep monitoring the battery voltage and try to start the car. It should not drop below 11 volts.
Get the car started (however, jump start, push start) and check the voltage. Should be around 14 volts.
Let us know the results.
Old Aug 28, 2013 | 07:57 AM
Drag0n97's Avatar
Did u add a extra ground?!
Old Aug 28, 2013 | 07:58 AM
Drag0n97's Avatar
If u can pop start it then add the extra ground
Old Aug 28, 2013 | 08:37 AM
njmaxseltd's Avatar
Ignition switch.
Old Aug 29, 2013 | 09:42 PM
DB206's Avatar
Update
Update:
I screwed up when installing the new starter and crossed the positive and negative - which is why the ney starter didn't work. I put the old one back in, which of course was dead. I re-installed the new starter correctly and it resolved my starting issue. NOW I fear I've damaged my electrical system, voltage reads anywhere from 12.3 to as low as 10.8 with the car running, I thought I damaged the alternator - replaced it to find out that the old one works fine! Had the battery checked, it's fine as well! All fuses are good and the grounds are hooked up?!
help!
Old Aug 29, 2013 | 09:56 PM
bprice92's Avatar
How olds the battery? does it hold a charge? Are the battery pos and neg terminals clean/corrosion free? check the negative grounding point, sand down to bare metal if need be, or even add a second ground to a clean point/not necessary though. Tighten terminals, should not be able to move them.. And maybe check fuses under hood? My electrical knowledge is limited to big audio setups, but ya know..just throwin stuff out there, gl.
Old Aug 30, 2013 | 01:40 AM
DennisMik's Avatar
In the box by the battery, check the 2 big fusible links (fuses) with an ohmmeter. Also check the small fuse (7.5 amp) that the cover labels ALT.S.
kjlouis
Nov 24, 2018 06:09 AM
ah2002
Mar 9, 2016 01:42 PM
Samedi
Aug 13, 2015 04:05 PM
Bruceharrison
Aug 9, 2015 07:56 AM
dauntlessmax
Aug 5, 2015 10:29 AM
