95 rack and pinion
Old Sep 5, 2013 | 12:02 AM
tim_minor's Avatar
95 rack and pinion
The dust boots have busted on it and I bought a new set of them. That being said... how hard is it to replace them. Is it going to be too hard for an inexperienced person like me to even try to tackle or should I just take it to a shop?
Thanks guys
Btw. I read the forum about the shaking at high speeds and I have that problem too with a fresh alignment but I haven't changed my tie rod ends.
Should I do this as well?
All input is appreciated
Old Sep 5, 2013 | 12:54 AM
Fakie J Farkerton's Avatar
You likely need your entire rack replaced considering the age of if.
There is a write up on how to do it in the 4th gen stickies.
Old Sep 5, 2013 | 09:01 AM
tim_minor's Avatar
Thanks man. I hope it's not too expensive.
Old Sep 7, 2013 | 11:32 PM
blakkrob's Avatar
If your gonna replace the bellows , i would do the tie-rod ends also. I replaced my drivers side bellows and it was easy. You kinda jack the alignment up while you are in there, i tried counting turns and still needed an alignment afterwards
Old Sep 8, 2013 | 05:57 AM
Trini Boom's Avatar
If you bought back the exact tie rod end that was there and your struts are OEM, it would not have needed an alignment.
mikeg75
Nov 30, 2015 05:12 PM
fastcarny
Oct 12, 2015 07:06 AM
06maxima55
Sep 28, 2015 04:29 PM
Serotta33
Sep 17, 2015 12:14 PM
