PIC attached. What is this hose called?
Old Sep 15, 2013 | 12:53 PM
ProV1's Avatar
howdy, yall
The thick hose marked by yellow arrow. What is this part called and what is its function? OEM part number? It was broken at the airbox end when I got the car.
Please ignore the red circles and text.
Thx
Old Sep 15, 2013 | 01:40 PM
DennisMik's Avatar
I can't really tell from the photo, i would need a more straight down from above photo.
The one with the yellow arrow is part of the PCV system and the one below it is the auto transmission breather hose.
Old Sep 15, 2013 | 04:44 PM
Aflion's Avatar
Yellow arrow is crank case vent hose. Just go to your local parts house and get the same size hose.
Posted from Maxima.org App for Android
Old Sep 15, 2013 | 04:55 PM
jholley's Avatar
I replaced that hose 5 years with one I got from autozone and it has held fine. Two years ago I replaced the cracked crank hose on the front side connecting the 2 valve covers with a hose from autozone and it also held fine with no leaking.
Old Sep 15, 2013 | 05:52 PM
ProV1's Avatar
problem is that the little plastic piece on the airbox that attaches to the hose broke off clean. looks like the only real permanent solution is to get a replacement airbox from a junkyard.
for now, i superglued the tube and taped it with gorilla tape as best as i could. pretty ghetto
btw, i ran the car for ~500 miles with the hose detached, and my MPG actually IMPROVED to ~24MPG from 21 MPG. However, it also set off "System too lean" error code after a while.
Old Sep 15, 2013 | 05:56 PM
Aburn95's Avatar
And I know what I'll be doing Wednesday before I drive to Atl....
Old Sep 15, 2013 | 08:15 PM
luke95gxe's Avatar
you shouldnt get a lean code for that i have ran for years with that hose detached and a breather filter in its place off the valve cover
conansriver
Nov 18, 2015 02:46 PM
catalinvint
Sep 16, 2015 07:48 PM
followthadollar
Sep 13, 2015 09:55 AM
dcam0326
Sep 7, 2015 07:26 AM
