sporadic problem with driver window.
Old Sep 21, 2013 | 06:52 PM
gruesome's Avatar
Hello,
Occasionally,.the driver window has trouble going down. I raise it up an inch then it lowers fine. I did have to take a chunk of styrofoam out of the door when I first bought it because that window didn't go more than halfway down. The styrofoam was broken.
Old Sep 21, 2013 | 10:06 PM
bprice92's Avatar
The power window regulator is probably on its way out.
Old Sep 21, 2013 | 11:13 PM
VQ3.02's Avatar
I've had plenty O' problems with my windows recently and for the junk yard price of around 40 bucks its worth grabbin the motor/regulator together.
Old Sep 22, 2013 | 02:51 AM
jfactor's Avatar
I've had bad luck with the window regulators on my 95, I've had to replace both rears. I wouldn't buy them from the junkyard which are cheap but since you don't know how old they are you don't how long they'll last before they break. I recommend ordering the parts from Rockauto, I've gotten a lot of parts for my max from them for lots cheaper than the auto parts stores. I've accumulated a little bit of info on what junkyard parts vs new/reman parts seem to be good if you're interested.
Old Sep 22, 2013 | 03:30 AM
gruesome's Avatar
Thank you, I've had pretty good luck with Amazon. Saved $30 on the camshaft positioning sensor that way versus the chain parts stores. Shipping on that was free because I got my code reader at the same time for.$43.
Old Sep 22, 2013 | 03:59 AM
gruesome's Avatar
Are the window and regulator one piece? They are on some cars so I wondered.
Old Sep 22, 2013 | 04:00 AM
jfactor's Avatar
No, glass and regulator are separate pieces. If you've ever pulled the door panels apart before replacement is easy.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
boomerbrian
Oct 31, 2018 10:25 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
