Bosch Platnium 4...WTF....HELP
Old Jan 16, 2002 | 05:26 PM
Dahnryman's Avatar
Put new bosch platnuim 4s in last night....the max has decided to start sputtering and back fireing...has anyone else had this problem with these plugs....#4418 i think they were....someone with any info please help.....
Old Jan 16, 2002 | 05:28 PM
Victim64's Avatar
Re: Bosch Platnium 4...WTF....HELP
Three letters NGK!!!!
Old Jan 16, 2002 | 05:29 PM
Dahnryman's Avatar
NGK is not what i asked
i asked for people with experiance with platnium 4s and why my car is dieing...........................
Old Jan 16, 2002 | 05:32 PM
Victim64's Avatar
Re: NGK is not what i asked
Should have asked that question before you put them in.... I have had those plugs so I would say I am experience.
But your sputtering problem is most likely because you dont' have all the clips done back tightly... Check, I bet one is loose.
side note.... Should have stuck with NGK though
Old Jan 16, 2002 | 05:34 PM
Maxilicious's Avatar
Re: Re: Bosch Platnium 4...WTF....HELP
Old Jan 16, 2002 | 05:38 PM
Dahnryman's Avatar
sorry....
you may know how one gets when thier car is not running....although i have check the plug connectors and they are tight...i attempted the engine code of the ecu it has one long blink and then just keeps blinking really fast and dosent stop....How tight did you have your plugs in...i was told to use onlyu 10-13 lbs of torq... the car seems to run fine when you get on it hard but its when you ...how to say.." normally drive it" it starts kicking out....it will idle fine and when you rev it it feels like a motor mount is out...whick the they are not.....
sorry bout the holla im just ****y....
Old Jan 16, 2002 | 05:48 PM
Victim64's Avatar
Re: sorry....
If you have an owners manual you can see what the right lbs of torque is... or there is sticky up top that will tell you. That might be right, I am not sure off the top of my head though.
I have changed my plugs out so many times though I never use a torque wrench any more. I just know how tight they are supposed to feel.
If you do have everything put back together correctly and the plugs are in to around about the right torque then you shouldn't be having this problem. However, I hate to tell you this again, but if I were you I would take them out RIGHT NOW and return them. BOSCH has a warranty on them and will take them back, just tell them that they made your car run funny. Stay with NGK's. If you want a performance plug or something go with NGK Iridiums (will have to change them out more often). Just some advice from a person that has tried MANY MANY plugs in my old 96 SE
Old Jan 16, 2002 | 05:50 PM
deezo's Avatar
II have +4's and my car runs fine with them. Try going over everything again. Check to make sure your all of the connectors are snug on each coil. Sometimes people put the connectors back on and don't push them all the way on. The plugs should work fine on your car.
Victim64's Avatar
7) Tighten the new plugs to 14 - 22 foot-pounds.
From the sticky above on Maxima Maintenance Items
Old Jan 16, 2002 | 05:57 PM
Victim64's Avatar
I agree to some extent... The plugs will work in his car, and he should not be having these problems.
BUT...
Old Jan 16, 2002 | 06:09 PM
CFster's Avatar
Maybe he cracked a plug while putting them in.
Old Jan 16, 2002 | 06:12 PM
bluefish's Avatar
bosch sucks
i am having the same problem...and my coils are failing
i am replacing all 6 coils and putting new NGK plus in this week...will let you know the results..
the bosch plus were platinium plus 4's and i ran them for the last 7 months...now major problems.
Old Jan 16, 2002 | 06:23 PM
deezo's Avatar
BUT...
Yeah, I'm going back to stock plugs in the Spring.
Old Jan 16, 2002 | 06:25 PM
deezo's Avatar
Re: bosch sucks
Hmmm......I've had mine for about the same or longer and still no problems. I've been racing hard throughout last year with them too.
Old Jan 16, 2002 | 06:46 PM
Dahnryman's Avatar
Re: bosch sucks
how much are coils hitting you for? have you had issues the whole seven months with the +4s? or just recently?
Old Jan 16, 2002 | 07:32 PM
Victim64's Avatar
Re: Re: bosch sucks
Have you fixed your problem yet??
Old Jan 16, 2002 | 07:41 PM
95emeraldgxe's Avatar
i bought those plugs once.....i didnt have any problems....i think u may have set the gap too low or too far maybe?
Old Jan 16, 2002 | 07:49 PM
Mishmosh's Avatar
Had Platinum Bosch plugs last year for about 4 months. Since the day they were put in, the car often had trouble starting up...sometimes needing an extra crank. When I took them out, all the plugs were oily--not quite fouled though. In went NGK and when I went to check those after a month, they were perfect looking. Car started up beautifully too.
Old Jan 16, 2002 | 08:06 PM
pocketrocket's Avatar
This might not help, but when I put new Bosch platinums in my Escort (sorry, I had to make my beater run! ), I accidentally knocked one plug while putting it in and messed up the gap. The engine ran so rough, so I took each plug out and found one plug had NO gap. Regap-ped it and it ran like a charm.
Might not help you though ....
Old Jan 16, 2002 | 08:19 PM
Victim64's Avatar
Your aren't supposed to gap +4's... they are pregapped
Old Jan 16, 2002 | 08:21 PM
AznStevie's Avatar
i got +4...the first day when i put it in..the car is sooo smooth hehe... no problem so far..i drive my car pretty hard too
Old Jan 17, 2002 | 04:30 AM
bluefish's Avatar
Re: Re: bosch sucks
the coils are about 50-55$ each with my nissan discount...could not get the code to isolate the bad coil so they all must go...
the last seven months were fine i guess...ever since the cold rooled in the cars running like sh*t... i have no experence with the NGK's... bought the car in 2001 and changed the plugs soon after..
The tech's at my dealership told me the bosch could through off the spark and resistance
Old Jan 17, 2002 | 05:50 AM
goldmax's Avatar
Re: Re: bosch sucks
I have had the Bosch +4s in my car for 45K miles now with no problems. I would re-check the installation and make sure that none of the plug electrodes got smashed. I would be suspicious of the back plugs which are much harder to install...it would be easy to smash the tip during installation.
Old Jan 17, 2002 | 07:04 AM
sinewave's Avatar
Re: Re: Re: bosch sucks
You may not be able to get an ECU code isolating the bad coil, but the dealership's Consult computer should be able to. This may be one of the few times that a dealer mechanic will save you money.
Old Jan 17, 2002 | 07:10 AM
Sprint's Avatar
do the spark plug change again.. trust me.. you might have missed somethign the first time.. take them all out.. and put them back..
Old Jan 17, 2002 | 09:43 AM
Maybe, unless you accidentally knocked the plug as you were putting it in and messed up the gap. I did that once.
Old Jan 17, 2002 | 03:57 PM
zagato27's Avatar
Bosch Plat +4s
I installed them in my Max about 30K ago and no problems. BUT, think that I'll go back to NGKs at 100K.
Cheers
Old Jan 17, 2002 | 04:25 PM
Eric L.'s Avatar
That should fix it. But if you are going to replace a coil or two, please also replace with NGK Platinum plugs. While some people here have had good results with Bosch +4's, I have not ever read an account of anyone having a problem with the stocker NGK's. Even Vincent Ciulla, the auto mechanic on About.com, says for nissans, use stock plugs, and he is a Nissan expert.
Old Jan 17, 2002 | 05:52 PM
Dahnryman's Avatar
Isolated the problem...
pulled the plugs replaced them with ngk... problems starting so i know it wasn't the plugs...what it seems to be was after i reset the ecu to get that ffing check engine light off....i restarted teh car to show my roomate what the deal was and it ran fine....don't know why but now its running great.... which is odd...mabey when i was putting the them back in i bumped whatever it was back in.....
whod of thought.....
anyone wanna buy some platnium 4s? lol
thanks for everyones help....
Old Jan 17, 2002 | 07:21 PM
Victim64's Avatar
Re: Isolated the problem...
NO Thanks!!!!
Cotozic
Jun 28, 2017 08:01 PM
00MAXI
Sep 2, 2015 10:23 AM
Maxboy23
Aug 21, 2015 11:02 AM
Superbform
Aug 11, 2015 08:10 PM
kajeno
Aug 31, 2001 10:15 AM
