Valve Cover Gaskets
Old 10-09-2013, 08:10 PM
redcoat's Avatar
Valve Cover Gaskets
quoted $460 to change both front and rear valve covers on my 95 Maxima...so I'm thinking of doing it myself.
Found some useful step throughs on here - seems more time consuming than tedious.
But, I would like some recommendations on which parts to use? Is it best to use original if I can find them? Or are the aftermarket sets I see online ok?
cheers,
David
redcoat is offline
Old 10-09-2013, 08:34 PM
Shift_A32B's Avatar
OEM valve cover gaskets are not that expensive. You can also use Fel-pro
Shift_A32B is offline
Old 10-09-2013, 09:08 PM
Slamrod's Avatar
cheers,
David
Yeah youd have to be insane to pay that much. Shouldnt be a difficult job at all just time consuming. You cant ever go wrong with OEM.
While you have the intake out you may wish to replace your knock sensor while your at it.
Edit: if for whatever reason you need to replace the covers themselves and not just the gaskets, your best bet would be the junkyard. No need to buy it brand new and get scraped by the dealership.
Slamrod is offline
Old 10-09-2013, 09:53 PM
jholley's Avatar
Here is a thread that can guide you in replacing those valve cover gaskets
rear-valve-cover-gasket-repair-info
I installed the FEL-PRO valve cover gasket kit 2 years ago and it has held fine. The PN is FEL-PRO VS50494R. You'll find them at rockauto.com for $36 + S/H. You'll also want to clean these parts and replace their gaskets while the plenum is removed:
http://forums.maxima.org/4th-generat...g-dummies.html
jholley is offline
Old 10-10-2013, 08:44 AM
LTXMitch's Avatar
take your time when doing it, $460 sounds right for a shop. i did it myself. clean your EGR, IACV and check all vacuum lines that make be broken
LTXMitch is offline
Old 10-10-2013, 09:08 AM
deezo's Avatar
Make sure to go over your hoses to make sure they're all reconnected and use RTV sealant to keep the new gaskets from leaking. I replaced the front cover first and it still had a little leak without the sealant.
deezo is offline
Old 10-10-2013, 11:36 AM
tosheto's Avatar
Change your PCV valve, and clean your TB and IACV.
tosheto is offline
Old 10-11-2013, 06:11 PM
98maxaholic's Avatar
gaskets (VC)
Ya OP my 98 with 100k is just starting to collect dirt on the front valve cover on the side, but its not leaking alot cuz i never have to put a drop of oil in between chages..and when i did my tuneup(plugs and etc.) to my pleasant surprise none of the plug cylinders had any oil in them at all,which 4th gens can be known for ,after they get some age to em.. bone dry(Thank god)
anyway if you do decide to do them yourself, keep us posted on how hard it was, ive done v/cover gaskets in the past but none that i had to take off the manifold!!aaaarrrgggh!!
98maxaholic is offline
Old 10-11-2013, 06:50 PM
redcoat's Avatar
Well, I found a local mechanic that was prepared to do both front and rear for $200, including the $60 kit.
Couldn't really pass that up, so he did it today. He said he guarantees it for a year, too - if they leak in the next year, fixes them for free.
Deal!
redcoat is offline
Old 10-12-2013, 08:06 AM
LTXMitch's Avatar
Deal!
Shoot I would of payed someone $200 just to do the rear one. That's a good deal
LTXMitch is offline
Old 10-15-2013, 01:32 PM
cashoit's Avatar
Deal!
Thats a dope price
cashoit is offline
TKHanson
11-24-2018 01:39 AM
jonreidhead
01-06-2016 09:38 AM
knight_yyz
11-01-2015 01:34 PM
tseng1023
10-15-2015 08:30 AM
Quick Reply: Valve Cover Gaskets
