Car shuts off but turns back on.. HELP
Old Oct 23, 2013 | 12:57 AM
Richie110's Avatar
I WARM UP MY CAR AND IS GOOD, ONCE I DRIVE AROUND AND CATCH A RED LIGHT, IT SHUTS OFF, BUT IT TURNS BACK ON AGAIN WITH OUT A PROBLEM, I CHANGE THE MAF SENSOR AND CLEANED THE BATTERY TERMINAL AND STILL SAME THING.. I GOT AUTOMATIC 1997 NISSAN MAXIMA THE CAR SHAKE JUST A LITTLE BEFORE TURNING OFF, AND WHILE IS ON IT FEEL LIKE IS GOING TO GIVE OUT, IT HAPPEN MOSTLY ON DRIVE BUT IT SHUT OFF ON ME 1's OR TIMES WHEN ON PARK, I JUST GOT A OIL CHANGE AS WELL.. PLEASE HELPPPPPPP...
Old Oct 23, 2013 | 02:33 AM
smokeypotter's Avatar
Idle air control valve? Maybe try turning up the idle a little if it's low? Sounds like cause its fine warming up while the idle is high.
Old Oct 23, 2013 | 04:30 AM
D.Stillwell's Avatar
Sounds like an idle issue since the car only does this when idling. My money is on base timing being off or IACV.
Bad MAF doesn't exhibit the kind of symptoms you described, neither does a bad battery terminal. Those two things you did will not hurt anyway, but no reason to throw money away.
Good luck with this
Old Oct 23, 2013 | 01:29 PM
Richie110's Avatar
Thanks alot guys
I went to the mechanic after he changed the mass airflow sensor because it was still doing it, and he replaced the crankshaft sensor and hardness, it was all replaced. Thank for all the help
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
Maxboy23
Aug 11, 2015 11:59 AM
kirkhilles
Aug 8, 2015 10:53 AM
