99 Maxima Rear brake upgrade suggestions
Old Oct 25, 2013 | 07:31 PM
Scottkastelic100's Avatar
Building 1999 maxima for Chumpcar series. I have the q45 rotor/caliper fronts, but q45 rears will not work. We want to go with a larger rear rotor that has some venting, (road courses, 7+hrs). What conversions have worked that are direct bolt in? We have limited brake modification rules and fabed caliper brakets are extra laps down.
Old Oct 25, 2013 | 08:44 PM
maxgtr2000's Avatar
KH3 by popular demand
Custom made bracket with larger disks maybe?
Old Oct 25, 2013 | 09:22 PM
Nealoc187's Avatar
SLOW
virtually no one upgrades the rear brakes. blehmco offered an upgrade for a while, but blehmco doesn't exist anymore, and it was expensive, like $700. it upgraded to a vented disk, different caliper, and a drum style ebrake (it was 300zx parts i believe, I don't recall if a bracket was needed).
best bet is to just get a bracket made and find a disk that meets your size requirements.
or just get the best pads you can for the rear and run some ducting to them to cool them on the dinky solid rotors.
Old Oct 26, 2013 | 05:51 AM
njmaxseltd's Avatar
Just run a higher temp race pad like Hawks in the rears and you'll be fine.
Most of your stopping power is in the front, that's where your upgrade should be.
Old Oct 26, 2013 | 09:30 AM
brakes
Ok, looks no one has done this. FYI: the maxima rear caliper only adjusts pad out when the car is in reverse. On the track going forward after 3-4 hrs pad will be worn down and will not adjust to compensate. That is part of the reason I want to use Q45 rears, they are self adjusting.
Old Oct 27, 2013 | 10:20 AM
saig's Avatar
Physics 101: a car slides down hill with
a. Front wheels locked up, or
b. Rear wheels locked up.
Which case makes the car uncontrollable?
Correct answer is b.
Old Oct 27, 2013 | 12:16 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/advanced-su...de-option.html
Old Oct 27, 2013 | 12:47 PM
Nealoc187's Avatar
SLOW
Hmm how did I miss that thread. Nice.
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
egali045
Aug 16, 2015 01:19 PM
09maxshawn11
Aug 14, 2015 10:07 PM
RealityCheck
Aug 5, 2015 06:18 AM
