couple tips for timing chain cover
Old Oct 31, 2013 | 03:06 PM
gruesome's Avatar
Howdy,.the recessed bolt in between the crank pulley and stud won't take a wrench and a ratchet won't fit, so I got a screwdriver welded to a 10mm socket.
You only need one part of a gear puller to get the crank pulley off.
The crank pulley bolt comes off easily if you put a 19 mm wrench on it with the other end touching the axle. Click the key a couple times to barely crank the engine, there you go. Impact didn't get it at 140psi.
Matt93SE
Apr 8, 2018 09:23 AM
maxinout93
Oct 27, 2015 01:29 PM
homeyclaus
Sep 3, 2015 06:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
yat70458
Aug 3, 2015 01:16 PM
