removing driver side exterior door handle
Old Nov 6, 2013 | 02:53 PM
whatnext's Avatar
My driver door handle and lock cylinder are loose. I removed the panel and saw that on e of the two nuts holding the door mechanism fell off. Found it in bottom of door interior. What would make the lock cylinder loose.
Old Nov 7, 2013 | 07:01 AM
jholley's Avatar
The cylinder fits snug onto the handle backed up by it's locking rod.
Removing-and-installing-exterior-door-handles
Old Nov 7, 2013 | 09:19 AM
Maxgig's Avatar
The lock cylinder is easy to fix, once you replace the nut there should be a locking C type clamp to hold the nut in place. If the C clamp is missing the nut will eventually come off from the vibration of the door being closed and the lock being used.
boomerbrian
Nov 8, 2015 05:10 PM
Stelianos
Aug 19, 2015 02:07 PM
shaunkey1
Aug 18, 2015 10:09 PM
