Stalls at low temperature
Old Nov 10, 2013 | 07:25 PM
Danik_k's Avatar
My 96 Max stalls when engine is cold!!!
It will keep doing it while I'm slowing down or stopped only until the temp arrow in near the middle of the gauge.
After a very-very long worm-up - no problem.
So, definitely temperature-related
Cleaned TB and Airflow sensor. (got a little better now, but problem is still here)
Codes:
1. P0125 - Insufficient coolant temp for closed loop fuel control
2. P0155 - 02 Heater Circuit (Bank 2, sensor 1)
Don't know which one I should troubleshoot first and don't know where those sensors are located.
Any link or directions are highly appreciated.
Old Nov 11, 2013 | 11:51 AM
bobflood's Avatar
Unlikely to be the O2 sensor. I would guess that your temperature sensor that connects to the ECU has stopped working. ECU doesn't realize that engine is cold, so doesn't provide enough fuel at idle and car stalls. Do a search for that sensor (may be called ECT sensor). It's at the right front corner of the engine as you are looking at it from the front; undeer a couple of things and in a coolant pipe.
The Bank 2, Sensor 1 O2 sensor is the one at the front in the exhaust manifold between engine and radiator. Easiest one to get to and change. Good luck.
Old Nov 11, 2013 | 11:58 AM
risingmist's Avatar
Also, if there just worked on the upper intake manifold or anything after the Mass air flow sensor. you may want to check for any un-metered air getting by.
Old Nov 11, 2013 | 12:55 PM
Danik_k's Avatar
Thank you very much for your input.
I found two things:
One is called Coolant Temperature Sensor ,
Another one is called Engine Temperature Sensor
Which one do you think it is
Old Nov 11, 2013 | 01:03 PM
Danik_k's Avatar
Just found a little crack in the radiator.
It is in that short plastic vertical tube, right below the cap. Very small amount of fluid is getting out when it boiling.
I don't think this is what causing the issue though. - Wanted to bring it up just in case
Old Nov 12, 2013 | 08:05 AM
bobflood's Avatar
If anything, this would more likely cause an overheat condition as the cooling system will not pressurize.
Old Nov 12, 2013 | 09:25 AM
asand1's Avatar
If you are loosing coolant through that crack, the sensors may be getting a false reading due to a pocket of trapped air in the coolant pipe. How is your coolant level in the radiator, not the reservoir?
The O2 heater circuit could be from a bad fuse on the O2 heater circuit. Or the heater element in the sensor itself may be bad.
Old Nov 14, 2013 | 09:59 AM
Danik_k's Avatar
I have the same concern (that is why I mentioned that): maybe, if there isn't enough coolant - the coolant temperature sensor doesn't have the proper readings and thus causing the problem.
Also, it could trigger the fans to turn on prematurely, what do you think?
I'm going to fill up the radiator (and the reservoir) to the top tonight and will see if the car will stall when it's full.
(it boils out through that crack on top though )
doctorpullit
Oct 28, 2019 10:58 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
