Anyone ever buzz off those 3 little nubs on the face of the headlight?
Old Nov 14, 2013 | 11:49 AM
Anyone ever buzz off those 3 little nubs on the face of headlight?
If so, how did you do it? With a dremel? or?
How did it turn out? How did you polish the area to smooth it out and hide any imperfections? Pics would be great
Old Nov 14, 2013 | 12:06 PM
Fakie J Farkerton's Avatar
Those add 5whp.
Old Nov 14, 2013 | 12:28 PM
schmellyfart's Avatar
Originally Posted by Fakie J Farkerton
Those reduce cd by 0.003
Fixed
Old Nov 14, 2013 | 12:38 PM
DennisMik's Avatar
Those "nubs" are there so the headlights cab be aimed with a machine. When you take them off, you will have to aim the headlights manually. No big thing, unless your state inspection checks with a machine.
Old Nov 14, 2013 | 03:01 PM
NickSm's Avatar
I filed those nubs off of both my 98 and 99 so that I could easily polish/restore the headlight plastic. I use a pretty rough file until I got basically even with the rest of the surrounding plastic, from there I used a 3M headlight restore kit to finish sanding them off and polish the headlight. One problem that can happen and unfortunately you won’t know until you do it. Not all of the nubs are created equal, out of the 12 that I sanded down one had too much of the headlight plastic pulled into the mold during casting. So after sanding I was left with a hole about the size of the lead in a #2 pencil, I fill the hole with clear epoxy. It turned out fine with a little extra $ for the epoxy and time to take the headlight out. I see if I can find my before and after pics.
I couldn't find the before pic. As you can see there is a little distortion where the nubs were but IMO it's much easier to clean and polish which is what I was after.
Old Nov 14, 2013 | 03:10 PM
Amerikaner83's Avatar
i used the yellow sandpaper that comes with the 3m restore kit..NBD and it looks pretty good...but I only did one of them (it was accidental)
Old Nov 14, 2013 | 04:32 PM
I used a dremel when I had eyelids way back when.
Old Nov 14, 2013 | 05:40 PM
eddie982's Avatar
i tried the stupid way, tried to chisel them off with a flathead and hammer aaaand found it impossible, lol.
Old Nov 15, 2013 | 08:42 AM
S1cTech's Avatar
I used an oh yeah. I bought aftermarket headlights lol
Old Nov 16, 2013 | 03:57 AM
jfactor's Avatar
Clearly you didn't do it on stock headlights Nick, since the stockers are glass, not plastic.
Wizard, I haven't seen a shop use one of the alignment tools these nubs are made for in years. I've always been able to successfully eyeball the alignment using nothing more than the ground and a wall.
Old Nov 16, 2013 | 05:40 AM
jcap's Avatar
I used a grinding bit then a sanding bit for a dremle then cleaned them and tinted them came out pretty good
Old Nov 16, 2013 | 07:40 AM
NickSm's Avatar
Really, Iv'e never seen a glass headlight for this vehicle. I wish mine were glass, maybe I need to hit the classifieds. Do the glass headlights still have an issue with yellowing? All of the glass headlights Iv'e dealt with in the past only ever have a problem with pitting.
Old Nov 16, 2013 | 08:02 AM
Not entirely true.
'95-'96 headlights are glass. '97-'99 headlights are plastic.
I wish mine were glass.
No you don't. They're flutted glass lenses.
Old Nov 16, 2013 | 02:33 PM
S1cTech's Avatar
um my 98 stock ones were glass and I replaced them with black trimmed glass ones as well.
Old Nov 16, 2013 | 04:13 PM
DennisMik's Avatar
Like ChrisMan said, plastic was used starting in 97. The previous owner of your car must have changed them.
Old Nov 17, 2013 | 01:36 PM
Thanks for the input guys, much appreciated.
I had no idea those were for aiming purposes with a machine. I figured they were just part of the molding process. Here in CA, we don't have any inspections for headlights, brake lights, brakes etc, just emission testing..so no harm in removing them.
Old Nov 17, 2013 | 02:36 PM
Shift_A32B's Avatar
Not entirely true.
My 97' had glass headlights...
Old Nov 17, 2013 | 06:54 PM
NickSm's Avatar
So, now the question is paper or plastic... I mean glass or plastic Wizard and are they stock?
Old Nov 18, 2013 | 12:02 AM
Nealoc187's Avatar
SLOW
i have never seen a 95-96 with plastic nor a 97-99 with glass unless a swap was done. anyone who has such has aftermarket headlights methinks.
Old Nov 20, 2013 | 11:54 AM
Yes, the Max I'm referring to is a 98 and the headlights are plastic.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
