How to tell if I have a standard or limited slip auto trans?
Old Nov 19, 2013 | 09:26 AM
pottzie's Avatar
Just checking on getting a replacement transmission (automatic) for my '97 Maxima. The first question they ask is "Limited slip or standard?" I didn't know there were two types offered, and was told that I probably have the standard one.
Any way to know for sure?
Old Nov 19, 2013 | 09:40 AM
Fakie J Farkerton's Avatar
Originally Posted by pottzie
Just checking on getting a replacement transmission (automatic) for my '97 Maxima. The first question they ask is "Limited slip or standard?" I didn't know there were two types offered, and was told that I probably have the standard one. Any way to know for sure?
Check the stickies.
http://www.pbase.com/cleanmaxx_brian/image/19276707
Old Nov 19, 2013 | 10:49 AM
pottzie's Avatar
Didn't see any help in the VIN guide, although thanks for pointing it out to me, might help down the road. All I see is something saying that Maximas can be either a32 or A33. No idea what the difference is between those two. Does that determine which tranmission?
Old Nov 19, 2013 | 11:07 AM
Aflion's Avatar
A32 is 4th gen Maxima, A33 is 5th gen Maxima. It's probably open diff. I think LSD was offered in the later Maxima's and I30's. You could jack up your car, spin a front wheel while its in neutral, and if the front wheels spin in opposite directions, it's open diff.
Old Nov 19, 2013 | 11:10 AM
NmexMAX's Avatar
dot dot dot ...
Might check the tranny code too.
A = open, V = VLSD
Old Nov 19, 2013 | 04:28 PM
jholley's Avatar
Originally Posted by nmexmax
might check the tranny code too.
A = open, v = vlsd
+1
Originally Posted by jholley
the metallic plate is on the passenger side firewall. Transaxle identification is on the bottom of the plate.
Re4f04a = open non slip
re4f04v = vlsd slip dif
re4f04h = hlsd slip dif
All 4th GEN Maximas sold in the US are non slip. Only Canada got slip differential.
Old Nov 19, 2013 | 07:09 PM
deathwobble's Avatar
Do a neutral drop. If only one tire spins it's a open diff if both spin you have a limited slip :-)
I'm just kidding don't really do that.
Old Nov 20, 2013 | 01:53 PM
pottzie's Avatar
Yep, it's regular non slip, just as everyone has said it would be. Thanks.
Old Dec 30, 2013 | 10:55 PM
1992maximase30's Avatar
+1
Re4fo4h = hlsd???
I didn't know the maxima/i30 had these
Old Dec 31, 2013 | 01:42 AM
Originally Posted by 1992maximase30
Re4fo4h = hlsd??? I didn't know the maxima/i30 had these
99.9%sure that hlsd was introduced in 2002.
Old Dec 31, 2013 | 04:16 AM
ABIGBRAIN's Avatar
Absolutely incorrect information right here.
Old Dec 31, 2013 | 10:04 AM
LTXMitch's Avatar
Go around a turn and stomp it. Your front right will spin through most of first gear.
Old Dec 31, 2013 | 10:37 AM
Not at all a tell tale.
I have VLSD and it's not consistent on which tire wants to let go and when. Road conditions, etc.
OP figured it out anyways:
/thread
Miket2006
Mar 1, 2021 03:55 AM
BobTX10
Oct 7, 2015 08:43 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
