Max rides like an empty dump truck
Old Dec 21, 2013 | 09:56 AM
bfghornet's Avatar
Hello everyone,
I have a question. If I already have new struts, what else would make my maxima ride soo rough?
Thank you guys for any help. Oh, and Merry Christmas!
Old Dec 21, 2013 | 11:02 AM
Fakie J Farkerton's Avatar
What brand did you go with?
Is the rest of your suspension up to par?
Old Dec 21, 2013 | 12:02 PM
deathwobble's Avatar
Are the springs stock?
Old Dec 21, 2013 | 01:24 PM
bfghornet's Avatar
Monroe is the brand. When I got those put in, it didn't make a difference at all. I also had both lower control arms put in at that time as well.
As far as the rest of the suspension... I have to admit I'm pretty ignorant when it comes to that subject .
Old Dec 21, 2013 | 06:36 PM
Alaskus's Avatar
Were the struts tightened correctly?
Is it the rear or the front? More noise or feeling?
Were they the Monroe quick struts? (All in one) or just the shocks?
Old Dec 21, 2013 | 07:29 PM
Slamrod's Avatar
Might be a stretch but perhaps it feels so stiff because you were riding on really old, worn out struts previously? Replacing old OEM struts with new OEM struts can be a big difference, let alone swapping in aftermarket.
Old Dec 22, 2013 | 06:10 AM
njmaxseltd's Avatar
Are they the Monroe Blue struts? If so, that's why it rides like a dump truck.
I had them for about a year, the ride was less than desirable.
Old Dec 22, 2013 | 09:40 AM
bfghornet's Avatar
I'm going to have to wait till tomorrow to ask my mechanic exactly what kind of Monroe's I have. The receipt does not specify which kind.
Also, besides the struts, are there any other culprits I should look out for?
Deathwobble asked if my springs are the originals, and they are. So I guess that is one culprit. I also have to assume my mechanic tightened them correctly, but I will still ask him.
Just to give you guys an idea of how harsh the ride is. When I run over those painted white lines at a red light, it feels like railroad tracks.
Thanks again guys for taking your time to respond.
Old Dec 22, 2013 | 09:51 AM
Have you checked the tire pressure?
Old Dec 22, 2013 | 11:42 AM
Slamrod's Avatar
If its that bad id say it is more than likely the struts themselves. In my limited knowledge i dont think anything else can cause a harsh ride like that.
Old Dec 22, 2013 | 04:56 PM
Les7311's Avatar
I had the same problem (after changing out struts) to find out I had to replace also:
Tie Rods
Lower Control Arm
Sway Bars
Go on online and you can get the above and more for under $200
.....these are all part of the suspension system, and will go bad. Have mechanic / alignment shop check them parts also....
Good thing is: I replaced the parts myself (thanks to Youtube vids)
Old Dec 22, 2013 | 06:49 PM
4th gen maxi's Avatar
Give you're front end a nice bouce its suppose to just bounce once on new struts.
If it don't oe too much its your spring rate too high.
Our max's already come pretty loose from factory. Gxe model has the softer springs over the se. Could be the moroe brand. ?
Old Dec 22, 2013 | 07:14 PM
ac max 92's Avatar
Did you change your swaybar links? If it's clunking over bumps giving you noise that's giving you the feeling that it's sounding like a dump truck i'd think about doing your swaybar links aswell.
Old Dec 30, 2013 | 04:36 PM
bfghornet's Avatar
Sorry it took me so long to respond. I have Monroe Sensa-Tracks.
Its just kind of strange to me that it rides just as same as it did with the old struts. It rides equally rough in the front or back of the car.
Thanks to all you guys for taking the time to help a noob out. And have a good and safe New Years Eve.
Old Dec 30, 2013 | 06:07 PM
njmaxseltd's Avatar
Those sensa-tracks should ride good. I think you need to really inspect your suspension for anything else that may need replacement. Check your tire pressure too. 32-35 max COLD.
Old Dec 30, 2013 | 06:41 PM
Nopike's Avatar
How long have you had this vehicle? Did it ride the way you want it in the past? It looks like you have an SE, they generally ride pretty firm at least compared to the other models. If you install new struts and springs the ride will probably just be that much firmer.
Old Dec 31, 2013 | 06:50 AM
asand1's Avatar
There is nothing wrong about a firm ride. The maxima is a "sport sedan", not a cadillac. I prefer a stiff ride and road feel.
Old Dec 31, 2013 | 11:20 AM
deezo's Avatar
Something isn't right. Maybe something in the suspension is binding. Even my car with Tokico Blues in the front and Illuminas in the rear doesn't ride that hard. I'm on H&R springs also.
Old Dec 31, 2013 | 01:13 PM
bfghornet's Avatar
Is it possible that bad motor mounts could cause this?
Old Dec 31, 2013 | 01:41 PM
metalgod3082's Avatar
Same issue here. Running over those little lights in the road it feels like my car is going to fall apart. Replaced every part of the suspension I can think of and same thing is still happening. I'm wondering if it may be the tires themselves even tho they are all fairly new.
Old Dec 31, 2013 | 02:48 PM
99maxwell's Avatar
you did say your springs are stock yes? just a thought, maybe too much spring sag? The springs may be worn out
Pixel
Sep 15, 2015 05:53 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
ag90fox
Sep 9, 2015 12:22 PM
Courtneysnow
Sep 4, 2015 05:10 PM
