Cruise control lights too bright !
Old Jan 17, 2002 | 03:01 PM
paul4b's Avatar
Does anyone have a suggestion for decreasing the light intensity from both the cruise control on/off switch and the cruise enabled light on the dash?
They're way too bright for me at night (Yeah I'm gettin' old).
I know that I could take apart the dash & wire in a series resistor or two series diodes to drop the voltage to the bulbs, but...
If I had the harness color codes, I could avoid modifying the dash iteslf, and just modify the harness.
Thanks in advance!
Old Jan 17, 2002 | 04:57 PM
pocketrocket's Avatar
Re: Cruise control lights too bright !
Old Jan 17, 2002 | 04:59 PM
matty's Avatar
There is a toggle switch on the right/bottom of your cluster...Turn it left alittle and all the lights in your cabin with dim...I never have it on full...it looks chessy
Old Jan 17, 2002 | 08:25 PM
jiaxima96's Avatar
I tried it and found it doesn't dim the cruise control main switch and the "cruise on" light and all the "warning" lights in the gause.
Old Jan 17, 2002 | 09:58 PM
95emeraldgxe's Avatar
change the bulbs or put sum tape over the button
Old Jan 17, 2002 | 10:00 PM
syc's Avatar
syc
one can always tint on whatever that is too bright
Old Jan 18, 2002 | 06:10 AM
paul4b's Avatar
Well, it looks like I'll be digging into the dash (hopefully this weekend).
I'll let you know my solution.
Old Jan 18, 2002 | 06:35 AM
jiaxima96's Avatar
My Haynes manual says for 96 to 99 max, the ASCD "ON" indicator wires are BLACK (ground) and GREEN/WHITE (goes to ASCD control unit). This is the one in the gauge area.
The bulb in the ASCD main switch on left side of steering wheel has two wires, one RED/YELLOW, and another RED/BLUE, the same color as many other lights such as ashtray, hazard switch, glove box, audio and CD player, etc. because those light bulbs are all in parallel.
The confusing thing is those light all go through "illumination control switch" that I think is the dim switch. However I never see the green light on the ASCD main switch dims...
Old Jan 18, 2002 | 11:49 AM
paul4b's Avatar
You know, I think the switch itself has a 'back-light' which is on the dimmer ckt. If it does (it would make sense to), it would allow you to find the switch when driving at night.
The green 'ON' bulb must be wired seperately.
If I get the time, I'll pull the switch this weekend.
Thanks!
Paul
stevesmax
Dec 17, 2020 11:57 AM
trasmadean
Feb 1, 2017 08:20 PM
schmellyfart
Sep 25, 2015 04:47 PM
vrajesh123
Aug 31, 2015 11:00 AM
220k+ A32
Aug 17, 2015 03:57 PM
