3.5 swap question
Old Dec 4, 2013 | 08:16 PM
P0tter7's Avatar
3.5 swap question
ok to start off I been bs about doing the 3.5 swap into my 5 speed 4th gen. I have read over the swap about a million and 1 times. I bought and integra and turboed that over the summer so I have been pushing it off soooo today I started to swap the timing. I happen to have an extra 3.0 here so im going to do the timing swap in my shed then swap the motor in one day so I don't have to rush. soo my question is witch I will do more research on but to pick some minds is I have an 05 3.5 motor and on the top it has the variable cam timing do they get wired in somewhere? the stock 3.0 don't have it. what I though as a lot of people do lsv swap in the Honda world couldn't I just wire the variable timing components to come on at a certain rpm. (they do wire it to a shift light so when you set the light lets say to 5rpms the light will come on. so what they do is wire the light to the varivle timing compont to come on at 5rpm instead of the shift light.) would that work?
Old Dec 5, 2013 | 06:37 AM
Zach-R's Avatar
I've wondered the same thing but I don't know how the variable system works. Hopefully someone will chime in with a definite answer.
Old Dec 5, 2013 | 07:20 AM
Maximeltman's Avatar
Yea I wondered same thing like can I control the vct with a remote switch or like with say emanage ultimate like maybe using the one wire that you can activate the 00vi solenoid (if doing the 00vi swap) but I think I remember somewhere I read that it won't work for some reason.
Old Dec 5, 2013 | 07:54 AM
95naSTA's Avatar
Since you swap static 3.0 cam timing on, the pwm vtc solenoids can't do anything anymore. They don't get plugged in.
Old Dec 5, 2013 | 09:40 AM
litch's Avatar
The timing chain adapters that you will use prevent vvt from working, they are like 95naSTA said "static." While doing the swap take a look at the little adapter rings and you will see where the peg moves to adapt to the 3.5 engine. Now if you are concerned with your lack of vvt, get some big boy cams and then you wont have to worry at all...
but as a general rule those cams are quite
Old Dec 5, 2013 | 09:48 AM
Fakie J Farkerton's Avatar
I wish I did upgraded cams.
Use that top end power.
Old Dec 5, 2013 | 10:17 AM
yea I thought op was suggesting just throwing in the whole unmodded 3.5, but now I remember another reason why this won't work, the cam sensor on the 3.0 timing cover isn't on the 3.5 timing cover, and the vtc gears don't have the same magnetic triggers either!!!
Old Dec 5, 2013 | 05:41 PM
Zach-R's Avatar
What is considered big boy cams? JWT? Are regrinds an option?
Old Dec 5, 2013 | 06:40 PM
litch's Avatar
jwt, cower... stuff like that.
Old Dec 5, 2013 | 07:54 PM
ABIGBRAIN's Avatar
Originally Posted by litch
jwt, CROWER... stuff like that.
Fixed
Old Dec 6, 2013 | 08:13 AM
Nealoc187's Avatar
SLOW
you read over the swap procedure a million and 1 times and you don't know what to do with the VTC? really?
Old Dec 6, 2013 | 09:53 AM
litch's Avatar
Originally Posted by ABIGBRAIN
Fixed
I dun been sniped.
I<3 A32's
Sep 10, 2015 11:07 AM
MaxLife17
Sep 8, 2015 02:36 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
