1995 Maxima Jerking and hesitating. Won't start.
Old Dec 6, 2013 | 07:03 PM
clane1012's Avatar
My son has a 95 Maxima that, (when it cranks), idles fine but when you are driving down the road it hesitates, almost like it has bad fuel. He had the diagnostics ran, bad crank sensor, knock sensor, and 1 other. Of course he can't remember the last. Prior to replacing the crank sensor this evening, the car would not start. I replaced the sensor and with a little gas pedal the car cranked. We took it for a test run, and sure enough the hesitation and jerking was still there.
Any ideas?
Old Dec 6, 2013 | 07:10 PM
Trini Boom's Avatar
We need to know what the 1 other code is. It seems that you already replaced the crank sensor and the starts up now. It sounds like the other code is a misfire but need to know in which cylinder if that is the other code.
Old Dec 6, 2013 | 07:40 PM
clane1012's Avatar
after taking it on the test run, it failed to start.
Old Dec 6, 2013 | 07:46 PM
clane1012's Avatar
And, the temp gauge jumps around. I have read other threads with similar problems, and some suggest replacing the temp sensor.
Old Dec 6, 2013 | 07:47 PM
clane1012's Avatar
we live in NC where it was 75 degrees today.
Old Dec 6, 2013 | 08:23 PM
LTXMitch's Avatar
Replace the knock sensor and the other then try again. I bet it will run fine then
Old Dec 7, 2013 | 11:55 AM
99zx2's Avatar
You need: fuel, spark, compression, and all the right time to start a car. By mashing the gas pedal when cranking this engine, you're actually cutting the fuel off.
My hunch is on fuel. Prime the pump a few cycles, then try to start it.
halfpol
Oct 17, 2022 12:16 PM
Team STILLEN
Aug 10, 2015 04:29 PM
halfpol
Aug 5, 2015 08:24 PM
maxima297
Aug 3, 2015 12:50 PM
