Fuel Line replacement
Old Dec 27, 2013 | 09:56 AM
rhonster's Avatar
I need to replace the short fuel line running from the top of the fuel filter to the injector array. Before cutting the old off, can I get away with simply opening the gas cap as opposed to pulling the fuel pump fuse and draining the system to a stall? any other tips welcome as well ... thanks
Old Dec 27, 2013 | 03:25 PM
DennisMik's Avatar
Taking off the gas cap won't relieve the pressure. I don't feel that the amount of gas that comes out is that great, so I just wrap a rag around the hose to soak it up. If you don't want to do it that way, then I think pulling the fuse would be your easiest option.
Old Dec 27, 2013 | 03:49 PM
rhonster's Avatar
That sounds like good advice, thanks. I may just go that route not knowing how difficult it would be for the fuel pump to refill the line once it's been vacated...
Old Dec 27, 2013 | 05:28 PM
Slamrod's Avatar
Ive pulled the fuse on the pump and stalled my car, then opened the gas cap to relieve pressure when i changed my fuel filter. Youll get a little squirt but if you do both together you should have zero issues.
Took a couple extra seconds and some sputtering when starting the car after but nothing noteworthy.
Edit: just wanted to say to make sure if you pull the fuse and dont open the cap youll still have pressure. Learned this the hard way by getting trapped holding a fuel line shut and needing a family member to open the cap for me haha.
Old Jan 7, 2014 | 08:39 AM
Herald's Avatar
Don't skip the proper way of relieving the fuel pressure. Pull that fuse and stall out the car. Otherwise there's a very good chance you'll end up with gas shooting all over your engine compartment. And don't worry about starting the car up after doing the work.
Old Jan 13, 2014 | 04:01 PM
rhonster's Avatar
I pulled the fuse and the car still ran unabated for a minute or 2, with the cap open as well, so i just shut it down and went to work. Very little pressure. I soon realized the plastic top type filter was the culprit so, to make a nasty job simple, i loosened all the clamps above and below the filter and simply cut off the old lines, replacing them with new 5/16" fuel hose and new filter. Started up like there was no tomorrow. I guess these cars just love fuel so much, they can suck it up without a pump. No muss no fuss and glad to have the new lines on too. About $1 foot around here and the filter, $6.
Old Jan 14, 2014 | 12:18 PM
Herald's Avatar
Good deal!
Old Jan 26, 2014 | 07:00 AM
Herald's Avatar
By the way, where did you get the fuel hose? I'm trying to figure out the specifications for a another hose in the fuel system, but I'm not finding them anywhere...
Old Jan 26, 2014 | 08:03 AM
rhonster's Avatar
5/16" inner diameter fuel hose is available, by the foot, at a few places. I bought at Princess Auto and also saw a spool at a Prime Choice Auto Parts retail outlet where I got my new filter. They sell online too but im not sure about hose by the foot. http://www.primechoiceautoparts.ca/
I got some extra oem clamps at a pullyard here where you can strip parts from their revolving inventory, 4th generation maxima and altima being not hard to find. Prime have a smooth clamp like the oem, but not the exact quality. For whatever, dealers can order those if needed. My lower filter clamp was beyond reuse, the others fine.
I had to replace my fuel filler pipe a while back, there are 2 hoses leading to the tank, but sorry i've forgotten the diameters although they are well above the filter lines.
Cotozic
Jun 28, 2017 08:01 PM
00MAXI
Sep 2, 2015 10:23 AM
KristyKarina
Aug 23, 2015 09:53 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
