odemeter intermitent
1996 I30- ~97K- Each morning the odometer works for about 10 minutes- until car warms up completely- then stops for -usually- the rest of the day- speedo and everything else works fine- any suggestions?
mine had this problem for one day
then just started working forever again
My problem started when i pulled out the cluster. When i put it back in, the odo stopped working. I'm assuming it's a loose connection or something. Take out the cluster and unplug and replug it back in (all cables attached) see if that helps.
odometer
Originally posted by 95emeraldgxe
try pushing the brown connector in a bit harder.....actually - press firmly on all the connectors
I pulled the cluster this weekend- cleaned all the contacts-but did not open it up- reinstalled- tried it and it still stopped after about 12-15 miles of highway driving. speedo works fine- 96 I30- any suggestions?
Re: odometer
Re: Re: Re: Re: odometer
Originally posted by ejj5875
Do both stop working, or just the main one?
Re: Re: Re: Re: Re: odometer
they both stop working together- I think it might have something to do with the temp.- i droive in today with heat off and it worked up to 20 miles- i did think that the lights inside cluster may have heated it up inside the cluster.?
Can you reset the trip odometer? I know on an older Nissan that I've had, the reset button froze, and locked up the trip odometer. It wouldn't work at all...but the main one still worked fine.
Re: Re: Re: Re: Re: Re: odometer
Could be, but I wouldn't think so...you're the only person out of thousands on this board with this problem...
Re: Re: Re: Re: Re: Re: Re: odometer
i can reset trip odometer. and during the intial phase when it is working -it will reset to zero and start counting again. but at some point it will stop with the main odometer and stay frozen for the rest of the day.
Re: Re: Re: Re: Re: Re: Re: Re: odometer
What happens when you reset it when the odometers aren't working? Does it just stay at 000.0?
Re: Re: Re: Re: Re: Re: Re: Re: Re: odometer
yes it resets to zero and stays there. i've tried punching it serveral times- no good
Um, I would think your next step would be to take apart the cluster and check for loose connections as mentioned...maybe even test the signal wire and trace it to see if its cracked or something somewhere. Sounds like a PITA. Sorry I'm not more help!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: odometer
Violence is always worth a shot.
Starrider
Sep 17, 2015 07:26 AM
Maxima-Will
Sep 15, 2004 11:36 PM
