Did I cause any damage? Drained coolent and blow air threw the lines
Old Jan 7, 2014 | 09:39 PM
fixandfly's Avatar
I am doing the 20 hour cylinder head job.
95 Maxima 3.0
The night before I started the repair
I drained the coolant
removed the upper and lower radiator hoses
and blew shop air from the top to the bottom
I did not use the drain plugs on the engine,
if the car sat outside for 2 days
with the temps in the teens 10-20 degrees
Fixandfly
Old Jan 8, 2014 | 04:41 AM
Turbobink's Avatar
So you're concerned that an "empty" and frozen block may have damaged something?
Or are you concerned that damage may have been caused by blowing the block empty?
Old Jan 8, 2014 | 05:04 AM
njmaxseltd's Avatar
The answer to your question is no.
Old Jan 8, 2014 | 05:41 AM
bewrong's Avatar
Beware of frozen mice.
Old Jan 8, 2014 | 06:12 AM
No harm, no foul.
Old Jan 8, 2014 | 06:20 AM
Turbobink's Avatar
Agreed ... no issues.
Just be sure to at least add water before start up.
Old Jan 8, 2014 | 08:18 AM
fixandfly's Avatar
just wanted to add that there was water in the
block cavity
and the water pump area
when I lifted the heads off
Old Jan 8, 2014 | 05:04 PM
chrome91's Avatar
no damage done. when you remove the heads, theres always going to be a bit of coolant still laying around
the only way you could have caused damage is by putting straight plain water in the engine and letting it freeze, youre up **** creek then
Old Jan 8, 2014 | 06:07 PM
fixandfly's Avatar
Thanks chrome91
The liquid in the engine was straight water
no antifreeze
but what you are saying
since it was not full to the top
and only had pockets here and there I should be OK
I know if it was topped off
with no room
I would have been in big trouble
Fixandfly
Old Jan 8, 2014 | 07:05 PM
chrome91's Avatar
Originally Posted by fixandfly
Thanks chrome91
no antifreeze
with no room
Fixandfly
full to the top you can blow out the frost plugs and do alot of damage. a bit of water most likely didnt do damage, but never let straight water sit in the engine like that
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
20
Sep 17, 2015 08:12 PM
conansriver
Sep 11, 2015 10:26 AM
jwright36
Sep 8, 2015 11:45 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
