Sea foam Opinion needed.
Searching and searching i just want a straight up answer. No flaming about this new thread.
Car has 146,600 miles.
Car was given to me with no history besides passing smog test. It was a gift. Has the leaking sound like if its heating a metal(heard its normal Catalytic Converter)
at times feels like it misfires at idle(rarely happens) heard it couple be coils.
gets about 19-20 mpg 300 miles per tank. I use Premium all the time. Either from mobil cheveron 76 or shell.
I do have the o/d blinking came out to be vss.
busted struts, needs alignment and just changed front rotors.
leaking a bit of oil now and then nothing to worry about at the moment.
Im thinking if i should use seafoam or just not put some in at all.
I was thinking about using it through the vacuum lines or gas tank. Ive had the car for almost 10 months. Sea foam or no sea foam?
Thanks?
Thanks?
Now i find out people say to get an oil change and air filter and spark plugs. due to the carbon being bugged up on the spark plugs.
i just dont have that much time to be doing that right now. I think im not gonna use it anymore.
How did you do it? I only planned on using it on the brake booster and maybe the gas tank.
I just did 3 weeks ago, was up for inspection and the car thrown EGR code though I cleaned EGR tube, IACV, TB a year ago so I used half can on vacuum line (brake booster) and poured the rest to gas tank, clean the code, pass the inspection, the code hasn't come back yet.
I assume you're talking about city or city/mix mileage?
Maxima should get around 440-492 miles per tank on the highway. I usually average out at 450 miles going 75-80 mph with ethanol blend. But that's straight highway driving 6-7 hours.
Although I also use premium, I find it doesn't make a difference in mileage. I once made it about 210 miles on a half tank of regular gas driving between 70-85 mph. I must have had a teaspoon of gas left
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
97_GXE
Sep 15, 2015 06:47 AM
