95 maxima code 14 on check engine light
Old Feb 1, 2014 | 02:14 PM
maxinout93's Avatar
Got a code 14 today as I checked my ecu. Engine has high idle when coming to a stop or in park. Its around 8 or 900 then will settle down to about 7. Sometimes acts like it wants to die at around 400 rpms. What does this code mean? How can i fix it?
Old Feb 1, 2014 | 03:58 PM
njmaxseltd's Avatar
No such code as 14. It blinks a series of short and long blinks followed by a pause.
Example: 3 short followed by 9 long is code 0309.
Try to pull the code(s) again and post back.
Old Feb 1, 2014 | 08:10 PM
DennisMik's Avatar
blink code 0104 = P0500, Vehicle speed sensor.
Old Feb 1, 2014 | 11:13 PM
maxinout93's Avatar
Thanks man, I thought it was something fuel related, I did notice the speedometer not moving at all for a little while, then it kicked in. Oh well gotta take the cluster apart.
Old Feb 1, 2014 | 11:18 PM
Maxima 97 SE's Avatar
no you dont take guage cluster apart. Its a sensor attached to the transmission you take ou and change.
Old Feb 3, 2014 | 11:01 AM
maxinout93's Avatar
I dont know because I just replaced the speedometer with one from an se, My original one never gave me problems, So im thinking its the cluster. Correct me if im wrong. If it is the part on the transmission do I pull the whole speed sensor gear out or just the top plug part?? That whole thing seems impossible to remove.
Old Feb 3, 2014 | 08:24 PM
Alaskus's Avatar
Pull the cluster back out - make sure all the screws are tightened.
Old Feb 4, 2014 | 12:47 AM
maxinout93's Avatar
Ok will do!!!
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 13, 2015 04:05 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
yat70458
Aug 3, 2015 01:16 PM
