Cutting Stock Shifter?
Old Jan 19, 2002 | 09:52 AM
Mad Dhan's Avatar
I was wondering if anyone here had cut their stock shifter, how did u do it and how many inches did u cut off? I searched for this topic but i count nit find anything. Any help?
Old Jan 19, 2002 | 10:49 AM
Justin95SE's Avatar
yes i did that
i cut it off my stock shifter and my STS. i think i lopped off about 5 inches. just enough to keep the **** from being recessed in that little hole where the boot is. I used a hack saw and a magnet to collect the shavings. I love the shorter way better.
Old Jan 19, 2002 | 11:18 AM
95emeraldgxe's Avatar
i woodnt feel confident doing that.......just spend a few bucks and get the short throw
Old Jan 19, 2002 | 11:22 AM
SpeedFrk38's Avatar
Re: Cutting Stock Shifter?
superchiu did that and there was no problem. he cut it about 2.5 inches. just so you know, it doens't reduce the throw but the height of the shifter so you won't get the efficiency a short throw kit will give you but have the look of a short throw kit.
Old Jan 19, 2002 | 01:43 PM
NotNew!!NewSN!!'s Avatar
rip ur stock shift **** off, cut it down about 2 inches, put a nice momo round **** on it, and enjoy, shifts are not harder, they are "crisp", the stock setup is something out of a pickup truck
Old Jan 19, 2002 | 01:50 PM
sil SE's Avatar
dont worry just do it. it will take you a while though. use a good SAW. forget ripping the **** off (manual?) that crap is mad glued. but i guess not impoissible to take off. i had to cut my **** off. jus cut the whole thing off- but it looks much better. plus your leverage is a lil better
Old Jan 19, 2002 | 02:04 PM
Mad Dhan's Avatar
yeah i was tryin to get it off and i couldnt. Damn the reason i wanted to do this cause it was cheap. Anyone know an easy way to get the **** off. I would like to take the **** and try to make an illuminated set up and cut off about 2 inches
if not how much do sts go for?
Old Jan 19, 2002 | 02:31 PM
Mishmosh's Avatar
The cut down is somewhat of a lot of work for so little gain. Sure it looks better and but you never escape that the throw is so long. Do yourself a favor and go for the STS right from the get-go. Pacesetter is only $70 from JCWhitney. Install is the main problem but it is doable. Even on my 95 with rust, it took me about 2.5 hours. It's tight under there and you will get a stiff neck but it is sooooo worth it. The STS is one of the most fulfilling mods out there for a 5 spd. I tried the cut down. Ended up ordering the STS a few days after... It is not worth the time and money (saw, universal ****) spent on the cut down. Get the STS and a quality screw down **** (instead of the universal) and you will have a great setup.
Old Jan 19, 2002 | 02:35 PM
heeheehee - how about cutting the thing on an automagic
Old Jan 19, 2002 | 02:42 PM
clee130's Avatar
Sure ... ny96max did it to his shifter. I forgot my camera last night or I would have taken a pic.
He has the Levoc shifter too... looks nice.
Old Jan 19, 2002 | 09:27 PM
RedMax95's Avatar
i did it too, and i also rewired the od
Old Jan 19, 2002 | 10:03 PM
SpeedFrk38's Avatar
redmax95 ... got any pics of the "new" a/t shifter?
Old Jan 19, 2002 | 10:55 PM
sil SE's Avatar
its not that much work. its a lil tough but its not difficult. personally i think taking off one emblem is tougher than this.
to me, cutting the shifter and getting a short throw are two completely different things. its not worth comparing.
if you wanna jus do something for free, and make you feel a litle better, cut the damn thing.
Old Jan 20, 2002 | 08:53 PM
RedMax95's Avatar
ive got one on the homepage, if you need to see anything particular on it i have a digicam
Old Jan 22, 2002 | 01:22 PM
Justin95SE's Avatar
it doesnt give the look of a STS
STS are just as tall. I cut my STS also. Feels way better. Install is really easy, if you try and have any questions, ill do my best to answer them. There was only one tricky part to the install and that was separating the shifter from the pivot point. I dont drive a truck for a reason, and a tall shifter is one of those reasons.
Old Jan 22, 2002 | 01:42 PM
SuDZ's Avatar
Like they said get the STS and get the look and performance of it.
SuDZ
Old Jan 22, 2002 | 02:26 PM
Mishmosh's Avatar
Re: it doesnt give the look of a STS
Depends what STS you have. Pacesetter/SMC when adjusted for short throw, also results in a significant height reduction from stock. If you ever plan to get a good screw down ****, please do not cut down you STS. I had a universal **** which was held to the shaft with 3 screws. It didn't compare to the Sola Luna **** that I have now which screws down tight and sits lower than just about ANY universal **** because the top of the STS is situated at near the top of **** once threaded down all the way. It just feels so much more solid and connected. Every little vibration is transmitted and shifting feels more precise.
I highly recommend Pacesetter. I highly recommend the Sola Luna *****. For the price you can easily get the STS and Sola Luna **** together for the price of other STS's.
Sola Luna **** at RSpeed, $39.95
aw11power
Oct 10, 2021 04:57 AM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
