synthetic OIL?? any cooler??
Old Jan 20, 2002 | 05:39 PM
sunnyb32's Avatar
hey all
i hafta get a oil change i've been using regualar ****ty oil (evey 3k) i am thinking to get synthetic oil put in this time my max has 105k and the temp bar/line is always through the center of the meter..seems kinda hot eh??? can someone give me a sugguestion to what kinda sythetic oil to use?? and how long will the full synthetic mobile oils run?? what should i use 5w-40 or what??
thanks all
Old Jan 20, 2002 | 05:45 PM
wope's Avatar
mobil 1 tri-synthetic is what i use.
Old Jan 20, 2002 | 05:48 PM
krzymax's Avatar
Maxima owner since 2000
i use fully synthetic 5w50
Old Jan 20, 2002 | 06:25 PM
clee130's Avatar
Please read the thread titled "Oil and ATF Analysis Spreadsheet" up top.
Thank you.
Old Jan 20, 2002 | 07:05 PM
iwannabmw's Avatar
You're not going to notice a significant difference in temp. unless you're really running the car hard. Synthetics will protect better in those cases and will help on start-up. For drain interval, clee130 showed you were it's at. Your water temp starting to climb at those mileages could be a corroded radiator, especially if the coolant hasn't been changed much, or it could be simply the water pump itself is starting to go.
Old Jan 20, 2002 | 09:31 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: synthetic OIL?? any cooler??
my temp needle is at the center of the guage during normal operating temp too.
Old Jan 20, 2002 | 09:45 PM
iansw's Avatar
Re: Re: synthetic OIL?? any cooler??
So is mine...ever since I bought it.
I think that's perfectly normal operating temp.
Old Jan 20, 2002 | 10:01 PM
Kevin Wong's Avatar
Running in the middle is perfectly normal; anything higher or lower would mean problems. This is not the oil temperature meter, I believe it's the coolant or water temperature gauage. That is why your car overheats when it goes too high.
I've been thinking about installing an oil cooler on my car. I'm using Mobil 1 tri-synthetic and have about 50K miles on it.
Old Jan 21, 2002 | 06:09 AM
sunnyb32's Avatar
If i use Mobil 1 tri-synthetic how long (miles) should that last, how often should i change it ?
Old Jan 21, 2002 | 06:17 AM
iwannabmw's Avatar
Right, this is the guage for water temp, there is no way to guage oil temp unless we install a guage ourselves. The normal reading is in the middle of the guage, if it is there everything is fine. Maybe I misunderstood the first post, I read it as the needle passed through the middle of the guage and was reading a little higher. Sorry if I alarmed people thinking all their cars had problems.
Old Jan 21, 2002 | 06:19 AM
iwannabmw's Avatar
Re: Mobil 1 tri-synthetic
As mentioned before, the oil analysis sticky will give you some great info. I just drained Mobil 1 5w-30 after 8000 miles, and sent it in for analysis to see how it held up, but I'm still going to Amsoil anyway.
Old Jan 21, 2002 | 06:22 AM
marcel's Avatar
I use Mobile 1 tri-synth oil with a good quality filter
and change oil/filter every 6k miles.
Old Jan 21, 2002 | 07:28 AM
dwapenyi's Avatar
I noticed
When I used regular oil, my temp gauge was right smack dab in the middle. I switched to synth, and the temp gauge sat a bit lower than the middle. To prove my own point I switched back to regular to see what happens. After like 2 days, the needle went back to smack dab in the middle.
Now, I've settled on semi synthetic, and the temp gauge always stays just below the middle are. So, synth or even semi synth oil makes your car run cooler. If the temp gauge, which is measuring the coolant temp, not the oil temp, can see it, then that's really good, because its picking up the change in-directly.
By the way, I know this gut who has a jetta, and those cars have the digital temp gauges. He noticed a big drop in temp when he switched to synth oil.
DW
Old Jan 21, 2002 | 12:36 PM
ZXdude's Avatar
I'm changing the filter every 3,000-3,500 miles and the oile ever 6,000-7,000 miles
Old Jan 21, 2002 | 10:13 PM
wope's Avatar
4000 is recommended
Old Jan 22, 2002 | 08:58 AM
sunnyb32's Avatar
ok switching to synthetic after 105k
i've used conventinal oil for 105k....my engine wont have porb or anything if i suddenly put synthetic in it right?? should i start wit semi-synthetic or fully?
thanks for all the help guyz
this is what i'm thinkin to do
use mobile 5w-30 synthetic and nissan oil filter and change them both at 8000k should that be ok??
Old Jan 22, 2002 | 09:01 AM
sunnyb32's Avatar
engine will be fine ?
i've used conventional oil for 105k and now if i suddenly use synthetic engine should be fine right?? should i start wit semi-syth or fully??
i'm thinking to use NISSAN OEM oil filter and mobile 5w-30 sythetic and change them both at 8000k should that be ok??
Old Jan 22, 2002 | 09:59 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: Re: Mobil 1 tri-synthetic
Originally posted by wope
4000 is recommended
Who recommends that?
Old Jan 22, 2002 | 02:27 PM
iwannabmw's Avatar
Re: Re: Re: Mobil 1 tri-synthetic
Probably you're average, friendly rip-off oil change place
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
Fbana41
Aug 29, 2016 12:18 PM
05RLS2
Apr 14, 2016 11:49 AM
