Interior light wiring
Old Feb 24, 2014 | 05:19 PM
bubbaaddison's Avatar
Does anyone have a diagram or can tell me How the switch is wired on the interior dome light? I installed some l.e.d. light strips in my car and would like to hook them up to that switch so they will come on when opening the door or the other option I thought is pretty cool for a 95 maxima is that I can turn that light on or of from my keyless remote. Again It's a 95 maxima. Thank you.
Old Feb 24, 2014 | 09:40 PM
DennisMik's Avatar
It is a fairly simple circuit. One side of the light is wired to 12 volts via fuse # 26. The other side is connected to ground by the BCM when the lamp is to be lit up.
The wire that gets grounded to light the lamp is a red with white stripe. It runs up the the dome light in the left side windshield pillar. You will see 2 connectors in there. The wire you want is in the bigger (8 wire) connector.
see page EL-277 in the service manual.
http://boredmder.com/FSMs/Nissan/Maxima/1995/EL.pdf
Old Feb 25, 2014 | 08:05 AM
Thank you for your help. I was able to get them wired up and it work just like I wanted it to.
Matt93SE
May 24, 2019 02:58 PM
rbaker100
Aug 28, 2015 08:11 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
