how much would you pay?
Old Mar 13, 2014 | 04:01 PM
LuminousX's Avatar
So I bought a exhaust, and I got it today, I live in the queens area of new York, and I wanted to know how much you guys would pay to a shop to have them weld it on? Max amount
Old Mar 13, 2014 | 04:28 PM
ac max 92's Avatar
What part of the exhaust? I'd probably say no more than an hr to 2hrs labour depending on what your shop charges. Where i am i had mine custom made mandrel bent etc. catback costed me $200 installed and custom y pipe made and installed $280 so basically my whole exhaust from from to back custom made and installed at $480 mind you i knew the owner of the shop.
Old Mar 13, 2014 | 04:30 PM
Finkle's Avatar
Depends on what you got, axle back, cat back, Y pipe or headers?
Cat back should be fairly cheap, mostly bolt on, take old off put new on.
In Wisconsin I can get a new exhaust made and installed for $250, so my number might be a little low compared to other parts of the county.
Old Mar 13, 2014 | 04:32 PM
Finkle's Avatar
Originally Posted by ac max 92
What part of the exhaust? .
Beat me to it.
Old Mar 13, 2014 | 05:01 PM
LuminousX's Avatar
I just updated my post with the link
Old Mar 13, 2014 | 05:49 PM
ac max 92's Avatar
Just a muffler. Shouldn't cost you much at all. Again depending on your exhaust shops labour rates. Should only be a half hr tops to mig weld on a muffler.
Old Mar 13, 2014 | 07:15 PM
JoshG's Avatar
take out ur old exhaust by using a hammer, put krazy glue around on new exhaust, stick it up onto the area where ur old exhaust was at.
Job complete! $0 spent
Just kidding.. lol should be around $150-230 for install, depends on shops to shops. Always call 3 and best to go the one who is in the middle. not too low or too high
Old Mar 13, 2014 | 07:24 PM
Quickywd01's Avatar
Guys he's just going to have a random hole in the wall shop bugger weld it on. $20 to "weld" it on. They are just going to chop and screw it on there. Going to take them 15 minutes.
Old Mar 13, 2014 | 08:04 PM
LuminousX's Avatar
150 to cut off the old an weld on the new, that's a rip off, job is 20 mins to half an hour
Old Mar 13, 2014 | 08:08 PM
Max139617's Avatar
Well being from Queens NY I can tell you where to go and how much to pay.
Go to the junkyard by citifield and just pull into any muffler shop. They will literally take 20 minutes to complete the job. Should be done under $40. If they quote you higher than that, just drive on the the countless other muffler shops.
Old Mar 13, 2014 | 08:15 PM
Quickywd01's Avatar
All the other people don't know how it is out here. lol We are not talking about a "performance" shop where it's done up like wizards supra. We have millions of hole in the wall shops around here. So I started doing everything myself. Might as well buy tools and do stuff myself. My boy bought a welder from a garage sale for $20 and he welds anything. This is what they are going to do: step 1, cut off muffler leaving oem pipe, step 2, weld new muffler inlet to oem pipe, step 3, make sure it' secure. Step 4, done. lol If you want it pretty, they can grind the weld smooth but who does that.
Old Mar 13, 2014 | 11:00 PM
LuminousX's Avatar
it's pretty much under the car so i don't care for pretty, I will check out citifield thou once I go to the shop that's like a block away from me, if it's not under 40 then no deal...
Old Mar 13, 2014 | 11:04 PM
LuminousX's Avatar
do you have the name of the junkyard or a address I could work with, I'm not getting anything on google
Old Mar 13, 2014 | 11:59 PM
I believe most reputable shops will charge $50 to $75 to weld on the muffler. I'm sure a handful of shops will do it for less if you shop around.
Old Mar 14, 2014 | 05:40 AM
Quickywd01's Avatar
A few years ago I paid $200 to have my warpspeed y-pipe installed along with hi-flo cat welded in and cat-back installed. They also had to weld the muffler back on the to b-pipe. That's how I bought it used. And this was a reputable shop. On the Cali spec 99 se auto. If it wasn't for the welding I wouldv'e tried myself. One shop I took it to the owner said you're better off buying a new cat-back. LOL no thanks I got that apexi for 1/7 cost of a new one and it had a 2nd resonator already welded in. Still have the exhaust swapped it onto my 97 se 5spd daily "beater".
Old Mar 14, 2014 | 10:39 PM
Max139617's Avatar
dude do you know where citifield is? Go there I guarantee you you will see the junkyards.
Google "citifield"
Old Mar 14, 2014 | 11:09 PM
LuminousX's Avatar
yeah i found it, got the muffler welded on, sounds pretty good
Old Mar 15, 2014 | 06:10 PM
Quickywd01's Avatar
How much they charge?
Old Mar 15, 2014 | 06:19 PM
LuminousX's Avatar
guy took 60, because he had to add a piece of pipe to it
Old Mar 15, 2014 | 06:22 PM
Quickywd01's Avatar
A little high but not bad. It sounds and looks good at the end of the day so it was worth it.
Old Mar 15, 2014 | 08:18 PM
LuminousX's Avatar
I said that to the guy, but he had already had it up on the lift, and what not so I just let him do it, appreciate the feedback
RealityCheck
Oct 2, 2015 06:34 PM
Socalstillen
Sep 26, 2015 12:01 PM
Cotozic
Sep 23, 2015 11:55 PM
ef9
Sep 10, 2015 10:35 PM
