Go my turn signals i couldn't wait and installed then 2 minutes later lol
Old Mar 19, 2014 | 11:40 AM
miguel1885's Avatar
what do you guys think
Old Mar 19, 2014 | 12:02 PM
Amerikaner83's Avatar
not bad
I'm a fan of clears personally....I only love the smoke look on darker cars. But that's just me. Glad you like 'em!
Old Mar 21, 2014 | 07:55 AM
Quickywd01's Avatar
Lookin good but replace those wheels with the SE 5-spokes.
Old Mar 21, 2014 | 03:40 PM
JoshG's Avatar
black rims would make it stand out
Old Mar 22, 2014 | 09:19 AM
Quickywd01's Avatar
It's too stock oem clean looking for black rims. Unless you bought some fancy smancy new shiny black mesh wheels with a chrome lip, not stock painted black.
Old Mar 22, 2014 | 01:07 PM
Alaskus's Avatar
hey... saw this in another thread. thought youd like to see it
its TallKin2201's footer
Old Mar 22, 2014 | 06:03 PM
NismoMaximaA32's Avatar
Do they sit flush and not loose? I had problems with 2 sets of clears from Ebay. Things kept falling out whenever I hit bumps so I used double sided type on them.
Old Mar 22, 2014 | 08:04 PM
Fakie J Farkerton's Avatar
Should have modified the new clears to fit the old clips.
Old Mar 22, 2014 | 09:45 PM
How would I go about doing that? I tried to use the screw and clips that came stock. But it seems the corners are slightly less wider than the stock ones.
Old Mar 22, 2014 | 10:01 PM
I used a drill to make the aftermarket pin hole larger..after unscrewing the pin of course.
Should be 10mm.
Then I removed the stock pins and chopped off all but about 4 threads because it was way too long to sit flush..then I just screwed it into the aftermarket.
I guess it made its own threads in the aftermarket because it's in there tight.
Hope that helps.
Old Mar 22, 2014 | 10:06 PM
My 15 dollar ebay clears have been on for two years without issues
Old Mar 22, 2014 | 10:11 PM
Some have too small of pins.
I've had three different sets.
One even came with new clips for the pins like they knew they didn't fit aftermarket without them.
Only one of three that I've had fit without small modification and it's the one that a mechanic broke when messing with my clutch hydraulics.
03VQMAX
Oct 2, 2016 09:36 AM
JRod28
Feb 4, 2016 11:07 AM
raffivegas
Aug 23, 2015 09:54 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
