Push Button Start
Old Mar 22, 2014 | 06:08 PM
Michael Feather's Avatar
Push Button Start
Putting in a Push Start Button in My 98 Maxima the issue that I am running into is the wiring to the ignition and which wire is what.
The unit is a Pivot the wires that run form it are 2 blue and 1 red.
Old Mar 22, 2014 | 07:40 PM
arcticracer's Avatar
are the three wires marked like b+, ig and st? Its been a while since I did mine but I remember the st wire from push button will have to be tied into 2 wires at the harness. The ig wire will connect to the harness wire that is 12v when key switch is turned to on position. Then the b+ will go to the largest wire that is always 12v.
Old Mar 22, 2014 | 09:10 PM
push Button Start
This is the diagram for the unit I have.
Old Mar 22, 2014 | 10:53 PM
I would do it this way:
Blue wire from push button tapped into white purple.
Blue wire from push button connected to both the black/white and red/blue wires. Cut and cap the side closest to switch don't just tap into them.
Red wire from push button tapped into white/blue.
It looks like you should also have a wire for ground from the push button probably black.
Old Mar 22, 2014 | 11:06 PM
push Button Start
I'll give that a try. Thank for your help this is going on day 3 driving me crazy also dose it make a referents between a A/T and a M/T.
Old Mar 22, 2014 | 11:47 PM
push Button Start
Question I have 2 blue wires you said one goes to white and purple. The second one to black/white and red/blue. I take it the r/p and r/bl connect to the single blue wire after they are cut?
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 8, 2015 02:23 PM
trungg86
Sep 4, 2015 04:58 AM
