1999 maxima
Old Mar 20, 2014 | 04:41 AM
maxima1963's Avatar
1999 maxima
i have a 1999 maxima on 3/6/14 did oil change on 3/13/14 the services engine soon light pop on we remove the battery post for hrs just to see if it will go off it didnt so took to gas station 1 code p0400 EGR,they reset the light,i finish running my errands car runs fine no problem,so i park car didnt drive it for 2 days when i went to go start the car it turns over but wont kick on
can some one give me suggestion
Old Mar 20, 2014 | 04:54 AM
Turbobink's Avatar
Your EGR tube is clgged ... just like the rest of us.
http://forums.maxima.org/4th-generat...ing-p0400.html
Old Mar 20, 2014 | 06:03 AM
maxima1963's Avatar
1999 maxima
so u dont think its the fuel pump
Old Mar 20, 2014 | 06:14 AM
njmaxseltd's Avatar
As Turbo said, your EGR tube is clogged, but that has nothing to do with your no start condition. You need to troubleshoot. First check for any stored error codes again. If nome are present, you need to check for 3 things, Air, Fuel and Ignition. Let's say the air is a given, you need fuel and spark. Which one are you missing? We can guide you from there.
Old Mar 20, 2014 | 06:50 AM
tigersharkdude's Avatar
What is this ... who can create the shortest subject line contest?
Old Mar 20, 2014 | 07:03 AM
maxima1963's Avatar
1999 maxima
im anita and i thank u all for the suggestions but i dont have anyone that could look at my maxima if there any mechanic's close in Gaithersburg,MD 20877 pls contact me thanks
301-407-1160
Old Mar 20, 2014 | 07:14 AM
Turbobink's Avatar
Originally Posted by njmaxseltd
... but that has nothing to do with your no start condition.
Yep ... sorry I zero'd in on the DTC and ignored the no start issue.
Apologies.
Old Mar 20, 2014 | 08:49 AM
DennisMik's Avatar
When you try to start the car, is the red Security led on solid?
Old Mar 20, 2014 | 09:26 AM
Amerikaner83's Avatar
THIS.
This is the number one thing you need to do right now.
Old Mar 20, 2014 | 11:06 AM
maxima1963's Avatar
were would i look for the red light at
Old Mar 20, 2014 | 11:07 AM
to the left of the steering wheel, next to the cruise control switch.
Old Mar 21, 2014 | 05:49 PM
maxima1963's Avatar
red light blinks
Old Mar 21, 2014 | 07:51 PM
vqmaxman's Avatar
Hi, I am vqmaxman i just called you and I am the closes mechanic that can help.
Old Mar 30, 2014 | 07:56 PM
maxima1963's Avatar
got the code check again @ found 2nd code crankshaft sensor @ got that @ now car runs
Stagnet04
Sep 2, 2015 07:53 AM
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
