Test Ecm
Old Apr 8, 2014 | 09:57 PM
intimidator's Avatar
How to test Ecm
I have a 1996 Maxima and I did a scan today and the following codes came up 0500,0325,0600,0443,1400,1105. Is there a way to test the Ecm and make sure that everything is working.
Old Apr 8, 2014 | 10:49 PM
DennisMik's Avatar
That's quite an assortment of codes.
P0325 = knock sensor
P0443 = EVAP Canister Purge Control Valve/Solenoid Valve
P0500 = Vehicle Speed Sensor
P0600 = Auto Trans Control
P1105 = Manifold Absolute Pressure Switch
P1400 = EGRC Solenoid Valve
Did this happen all at once or has the check engine light been on for a while/long time?
If all this happened at once, you may have a grounding issue. Check the main ground under the battery. Otherwise diagnose each code for what it indicates. Except the knock sensor code. This is usually a ghost code that likes to show up any time you have a legitimate code. Take care of everything else and this code will probably go away.
Section EC of the Nissan FSM covers these codes.
Don't have the manual? Get it here:
http://www.nicoclub.com/FSM/Maxima/1996/
page 10 will show you where most of the parts are located.
Old Apr 9, 2014 | 01:18 AM
I replaced EGRC Solenoid Valve and I am getting 12 volts to the unit but the code has not cleared.
Old Apr 9, 2014 | 05:00 PM
DennisMik's Avatar
The code does not go away instantly when you fix the problem. It stays in the ECM memory for a while until several drive cycles have passed. Or you can reset the ECM for instant results.
Old Apr 9, 2014 | 05:28 PM
4th gen maxi's Avatar
If the ecm sees an intermittent fault it will never go away even if you replaced the part.
And it automatically deletes any pending or hard faults after 40 drive cycles to be exact if it sees no faults taking place.
Old Apr 9, 2014 | 05:32 PM
bewrong's Avatar
What constitutes one drive cycle?
Old Apr 9, 2014 | 05:52 PM
Some parameters must be met.
Time passed since started.
Coolant temp. Rise over current temp. By 40F
All monitors must have passed and checked ok.
A single monitor such as the egr will not be completed going around town because it also needs to meet certain scenarios.(highway time)
In your case since you had a egr fault now that you replaced it is still not completed. Drive for a while. Cruise speed and decel is best for egr.
After the ecu sees no faults after 3 consecutive times(3 monitor rediness)light will go off due to a class A fault. Emissions
Or...or since you know you fixed the problem unplugged battery and in the morning run it. If MIL comes back on you know it has not been properly fixed.
Old Apr 10, 2014 | 01:47 PM
P0600 = Auto Trans Control. What do I need to work on to fix that?
Old Apr 11, 2014 | 09:55 AM
DennisMik's Avatar
In the 1996 service manual (link given in post # 2 above) go to section EC. Follow the index listing down to "TROUBLE DIAGNOSIS FOR DTC P0600", towards the end of the 2nd page. You might want to note for future reference that the list is numerical by the DTC P number.
Either click on the link or manually go to page 256 and follow the diagnostic procedure.
Old Apr 12, 2014 | 02:03 PM
I tested the ECM to TCM connector and everything checked out fine. I may have to change the TCM. How do I take out the TCM, it does not want to slide out?
Old Apr 12, 2014 | 02:35 PM
DennisMik's Avatar
Never had to remove one, so I don't know what is required.
Old Apr 12, 2014 | 11:48 PM
Since everything checked out with testing the connectors. The next best thing would be to replace the TCM or is there something else I should look into?
Old Apr 13, 2014 | 03:27 AM
DennisMik's Avatar
Wiring doesn't go bad that often unless there has been human intervention so I can believe that the connections tested OK. I would suggest another TCM, getting one from the junkyard. A new one from the dealer is expensive:
part # 31036-40U00, CONTROL UNIT-SHIFT, list price $605.
You need to get one from a 95 or 96. 97, 98 and 99 each have their own. I don't know what the difference is on them, though. It just might be the shift points and maybe not.
Old Apr 13, 2014 | 05:43 AM
LuminousX's Avatar
I had a p0600 code before, this you should know
1. if your speedometer works fine then it's not the VSS it's the Revolution Speed Sensor instead, that's what the giving you the speed sensor code, this will also cause your computer to send a p0600 code because the car would shift right or would go into "Limp" mode sometimes, or just don't wanna shift at all, the sensor your looking for (check the link for a picture http://forums.maxima.org/4th-generat...ed-sensor.html) is attach to the transmission that tells the tcm when to shift or the shift points depending on what speed your transmission is going, and it's located under the driver wheel once your remove the splash shield
P.S my post only counts if your speedometer is working, and that p0500 code states that it isn't so good luck
Old Apr 15, 2014 | 02:48 PM
Do you by any chance know what the part number is for the Revolution speed sensor. I am finding the vss part number but not the revolution speed sensor.
Old Apr 15, 2014 | 07:59 PM
LuminousX's Avatar
No I bought a used one from maxima Joe here on the org, they go for about 160 up if your buying new
Old Apr 18, 2014 | 08:26 PM
I replaced the Revolution speed sensor and I am still getting the same transmission codes. Not sure what to do next?
Old Apr 18, 2014 | 09:17 PM
DennisMik's Avatar
Well, the service manual says it could be the TCM. pm Maxima_Joe or visit your local junkyard.
Old Apr 19, 2014 | 05:48 PM
LuminousX's Avatar
I have a tcm I got from a junkyard few months ago when I had similar problem, after putting in the tcm I got the problem was still their, make sure you test it to be sure it's not working, if not then I could sell you mine, it's for a 96
Old Apr 19, 2014 | 10:52 PM
I replaced the TCM and still getting the same code?
Old Apr 21, 2014 | 05:43 PM
Every time I put in reverse and then put in drive to move forward it does not want move and then when rev the engine then makes a big jerk forward to move. Should I change the speed sensor next?
Old Apr 22, 2014 | 12:49 AM
LuminousX's Avatar
did you change the revolution speed sensor?
Old Apr 22, 2014 | 07:30 AM
DennisMik's Avatar
That sounds like the transmission in my 94 Max before it puked its guts all over the pavement.
Old Apr 22, 2014 | 01:01 PM
I did change the revolution speed sensor and still the same problem.
Old Sep 13, 2017 | 08:10 PM
Chittychittybangbang's Avatar
Any updates on this?
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
