Will I have to replace transmission?
Old Apr 13, 2014 | 05:56 PM
madoka's Avatar
Occasionally when I hit the accelerator from a complete stop, the revs will build up and then the car will bolt forward with a hard shake. Is there a fix for this or will I need a new transmission?
Also, on a probably unrelated note, there's an occasional high-pitched squealing noise when I press the accelerator.
TIA
Old Apr 13, 2014 | 06:23 PM
DennisMik's Avatar
That doesn't sound good. Have you checked the oil level in the transmission? If it is low, that kind of thing can happen. Take the car to at least 2 transmission places and see what they say. Avoid AAMCO.
The squealing noise could be a loose alternator or power steering belt.
Old Apr 14, 2014 | 01:10 AM
97_GXE's Avatar
yeah, i'd do a drain and refill on it with Vavoline or Matic. Also, are you being careful to allow the car to come to a complete stop when backing up before shifting between reverse and drive? That's a good way to kill a transmission if you're not. It's a bad habit I see people do all the time.
I had a friend tell me his acura tranny went out at 180,000 something miles. I told him if he keeps popping his car into drive while going in reverse, he'll be replacing it again soon.
Old Apr 14, 2014 | 08:48 AM
madoka's Avatar
Well, that escalated quickly.
This morning I found that reverse will no longer engage. I had to push my car out of my parking spot. All drive modes work fine, but reverse acts like neutral; rev the engine and no movement.
Is my only solution a new transmission now?
If so, should I be looking for a rebuilt one or rebuild the one I have?
Old Apr 14, 2014 | 09:19 AM
DennisMik's Avatar
If you go to a transmission shop that will do a complete rebuild on your transmission, that will run you between $2K and $2.5K. But transmission shops are Jekyll and Hyde. One place is good and the next one is terrible.
Buying a rebuilt transmission off the shelf (like a starter or alternator) is probably a little less expensive, but usually more problematic. This is what you get at AAMCO shops and why they are so bad.
When you look at the age of your car, I would suggest you find a used transmission and get that installed. The transmission would be in the $500 price range plus installation if you don't want to do it.
Old Apr 15, 2014 | 08:47 AM
CNunes_95's Avatar
Sounds like it is a transmission issue, which could be an insanely expensive fix. I drive a manual and my first gear would not lock in and whenever I put it in reverse, the entire car would shake. Then eventually, the other gears began having the same symptoms as the first gear did. I just got my transmission rebuilt by AAMCO and it ran me $1200.00 + tax and cost of parts... which then ran me up $2359. The car is now running great! But... Stay away from AAMCO... lol
Old Apr 15, 2014 | 09:21 AM
max ride 41's Avatar
used trans is the only way to go, rebuilds are iffy and don't last. i did a used trans 4 years ago and still holding together. have done the fluid exchange once as well. probably doing again soon.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
Cotozic
Jun 28, 2017 08:01 PM
PH98I30
Aug 20, 2015 04:25 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
