Weird noise turning sharp
Old Apr 16, 2014 | 04:49 AM
Patm-a32's Avatar
Hey guys this morning was differently cold then others and i noticed ***only on right sharp turns*** im gettjng a metallic scraping noise or a metal grinding sound and im not sure whT it is... Here's what i have done on that side to get rid of some culprits... New inner and out tirods new axle new bearing new control arm with ball joint and bushings new struts(including bearing, mount, everything) pads and rotors that have only about 8000 miles on them and the hardware on the brakes are new, also have new sway bar bushings, but i do need a new sway bar end link but its not broken so i dont believe it to be related... Any one have any ideas ? Or is it just the abnormally cold weather messing with my head lol
Old Apr 16, 2014 | 04:53 AM
njmaxseltd's Avatar
Check the splash shield behind the rotor. Push it away from the rotor with a long screwdriver. You don't even have to take the wheel off to do this.
Old Apr 16, 2014 | 04:59 AM
Patm-a32's Avatar
When my dust shields did that before it did it all the time not just on sharp turns like if im quickly going around a corner or getting on an on ramp or something doesnt make a sound on like stop and go right hand turns only on hard turns
Old Apr 16, 2014 | 06:28 AM
Patm-a32's Avatar
I agree ill check it out after work.... If it isnt that is there any other thing it may be ?
Old Apr 16, 2014 | 07:44 PM
chrome91's Avatar
theres metal bump stops that are meant to scrape if you max out the steering wheel to either direction, sounds like thats whats happening to me. my Crown did it last year, took a sharp turn and i heard a Bruuung Bruuuuung Bruuuuuuung noise so i looked underneath and the bump stops were clean and shiny
should never max out the steering wheel, its hard on the PS pump
Old Apr 17, 2014 | 06:31 AM
Patm-a32's Avatar
It wasnt a sharp turn it was just a turn like say im getting on an off ramp and im flying up it arojnd a bend it will do it
Old Apr 18, 2014 | 02:07 PM
chrome91's Avatar
in that case check the splash shields as said
alahjahwan09
18
Sep 21, 2015 09:12 PM
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
LtLeary
Sep 14, 2015 12:33 PM
bennuss
Sep 11, 2015 05:55 AM
