Where to check for corrosion/rust
Old Apr 28, 2014 | 07:33 AM
Patm-a32's Avatar
Hey guys So i have already gotten the lower radiator support re done with the oem part and it came out beautiful. As of now i have some rust on my rear right quarter that is being taken care of in a few weeks; is there any other spots i should be aware of or are commonly rusted on the 4th gens while im getting other spots taken care of ?
Old Apr 28, 2014 | 07:37 AM
Patm-a32's Avatar
Thought id ask around as ive gotten 3 years out of my max and the vq is still running beautifully at 154k along with the trans... So i plan to keep the car a while so long as it doesnt rust it self out lol
Old Apr 28, 2014 | 08:33 AM
Fakie J Farkerton's Avatar
Rear strut mounting points, check underneath everywhere especially the rear where the drain tubes exit.
Old Apr 28, 2014 | 09:31 AM
Patm-a32's Avatar
My floorboards are really bad to, but i plan to pull out the seats console and carpet to get access to cut out the bad metal and weld in new
Old Apr 29, 2014 | 07:23 AM
Finkle's Avatar
How are your rockers? Brake lines?
Old Apr 29, 2014 | 10:14 AM
Patm-a32's Avatar
Rockers are **** and brake lines are good
Old Apr 30, 2014 | 07:04 PM
Finkle's Avatar
Check out the rockers. IIRC there are three layers of metal between the outside and the carpet. In a couple spots all three of mine were gone, you could feel the carpet from the rockers.
Old May 1, 2014 | 07:58 AM
slfalco's Avatar
I am in NY, my 99 has rusted in the following areas: radiator support, rear wheel wells (starts in the seam between the outside sheet metal and the inside liner), rear quarters where the sunroof drains go through, rocker panels, brake dust shields in the rear, lower front fenders in front of the wheel.. I had the radiator support replaced at a body shop, replaced both front fenders, and patched the rest myself.. Also a recent inspection found that the license plate lights were both out, and the metal bracket that holds them was rotted away and disintegrated when trying to remove the bulb covers.. That $50 part is on its way... As the original owner, I am determined to get to 200K miles, at 185K now...
Old May 1, 2014 | 06:49 PM
jholley's Avatar
Originally Posted by slfalco
...... Also a recent inspection found that the license plate lights were both out, and the metal bracket that holds them was rotted away and disintegrated when trying to remove the bulb covers.. That $50 part is on its way......
Make your own license plate light bracket using this HowTo thread
http://forums.maxima.org/4th-generat...t-bracket.html
Old May 7, 2014 | 09:06 AM
barnone's Avatar
Check the undercoat on the floor pans at the front foot wells for delamination/flash rust. Look for wet carpet after driving in the rain. Or if you're feeling ambitious, pull back the carpet and check the seems around the floor pans.
HOKUSMAX
Nov 13, 2017 04:34 AM
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
