4th Gen Camber Front & Rear
I plan on lowering my 96 Maxima and am not sure on which set up to go with yet because I have 18 inch 6th gen Maxima wheels and dont want to lower it too much, but I am sure I will need a camber kit. I have seen a camber bolt for the front, but nothing for the rear. When I search I get nothing but results for other generations of Maximas.
Anyone have a rear camber kit in their 4th gen and if so how much did it cost and where would I obtain one?
The front end will need to be realigned and if you drop it to much a camber correction may be needed.
You don't have to do anything to the rear.
For more information on a solid rear axel click the link below.
http://lmgtfy.com/?q=Beam+axel
Front toe will have to be reset, as your track width in front will change some. No other alignment angle is adjustable though. The rear is a solid axle, it will not change at any ride height.
03VQMAX
Sep 25, 2015 04:19 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
CAN-Other LF: Worn / Broken Parts
george__
Aug 18, 2015 07:06 PM
