Ball joint trouble
Old May 9, 2014 | 02:15 PM
Patm-a32's Avatar
Ball joint trouble
So a weekend ago i swapped out my driver side control arm with new ball joints and it was fine at first, but a week later im getting nasty squeaking and creaking noises. Now i had someone push on the front end while i lied under the driver side and looked and the ball joint is the source of the noise... Its a brand new ball joint tho... The problem did not persist before the lca arm swap. When it rains out the sound 100% goes away until it is dry outside. Anyone else ever have this issue or have any suggestions please ?
Old May 9, 2014 | 03:02 PM
Fakie J Farkerton's Avatar
Check to make sure you tightened it all the way with weight on it/not in the air.
Old May 9, 2014 | 03:56 PM
Patm-a32's Avatar
How would the rain making it stop making noise have to do with that tho ? I'll check it tho thanks for the reply
Old May 9, 2014 | 07:46 PM
DennisMik's Avatar
No noise when wet and noise when dry makes me thing the ball joint needs lubrication. Does it have a grease fitting?
Old May 9, 2014 | 09:41 PM
Patm-a32's Avatar
Nope, it was an already greased ball joint there is no grease fitting
Old May 9, 2014 | 10:37 PM
Finkle's Avatar
could be LCA bushings. Spray some water on them and see if it goes away
Old May 10, 2014 | 06:57 AM
Patm-a32's Avatar
Already did, the sound is coming from the ball joint
Old May 10, 2014 | 07:15 AM
Patm-a32's Avatar
So just got it checked by my mechanic, i didnt change out the pin rod and i guess i mangled it quite a bit getting the old bushing off from the old arm causeing it to have some play in it
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
zmcneely13
Sep 26, 2015 02:26 PM
ivorton23
Sep 26, 2015 09:47 AM
