Refinished Metal Water Pipes
Old May 10, 2014 | 01:08 PM
CS_AR's Avatar
Today I finished refurbishing the metal water pipes that run along the left side (e.g. nearest the radiator) of the engine.
After sanding and refinishing the pipes, I used some ceramic VHT exhaust header primer and paint that I had left over from the Y-pipe. I've been slowly baking the pipes this afternoon to cure the ceramic paint before I do the installation. I've got to make sure the ceramic paint is fully cured and hardened before installing the o-rings and heater hoses. I did have to spend quite a bit of time sanding and polishing the hose connection areas to smooth off some rust that had formed between the hose rubber and the pipe. We'll see how well the refinished hose and o-ring connection areas will hold up over time. The pipes are now in better condition than when I started.
Here are a couple of picture that we may want to reference when someone has a water leak or needs to replace the o-rings or gasket. I like the Felpro gasket with the extra "red seal" area for the aluminum hose manifold mating surface. In the end, I reused some OEM o-rings that I already had on hand. I recommend using OEM o-rings as they will be the correct size.
I used 0000 steel wool to polish the aluminum pipe manifold o-ring and gasket mating surface areas. I might have been better off buying some new OEM pipes that come with a factory power coat. But we can see how long the refurbished pipes last in the mean time.
Pardon my phone camera, as the pipes are actually a silver metallic color that match the aluminum pipe manifold part.
Here are a couple of pictures with the refinished pipes on the car. Valve cover polishing was still a work in progress when I took a break to snap the following picture.
I changed the 10mm short bolts pipe mounting bolts to use hex cap heads with lock washers in the picture.
Old May 10, 2014 | 01:22 PM
Fakie J Farkerton's Avatar
Keep up the great work/posts!
Old May 10, 2014 | 05:29 PM
CMax03's Avatar
I've been keeping my eyes open for some new ones on a junkyard car! I wanna replace mine!
Old May 10, 2014 | 07:13 PM
CS_AR's Avatar
Refinishing the pipes baking the ceramic paint has been a small project in itself. The only reason I attempted it is the easy to reach location if something backfires on me.
As a side note, the OEM heater supply pipe on a VH45DE comes nickle plated from Nissan. So all I had to do when I got a new one was to polish it up a bit and then clear coat it for the long haul. On a VH45DE the pipe lives at the bottom of "death valley" buried under a Gordian Knot of hose and wiring harnesses. You don't want to miss anything that could come back as a leak or a problem after you put one of those critters back together. You can see it in the picture below the supply pipe running underneath the short pieces of head coolant hose.
Old May 10, 2014 | 07:38 PM
The_Fixer's Avatar
May i ask why you went paint instead of powdercoating? Btw alot of nice work you got going on
Old May 10, 2014 | 10:05 PM
CS_AR's Avatar
Thanks Fixer. I would have preferred to have gone powder coat. It would have taken a couple of weeks to have gotten the pipes powder coated. Time will tell if I made the right decision. If this ceramic paint doesn't work out, I'll pickup a set from a salvage yard and have them powder coated.
Old May 10, 2014 | 10:33 PM
CMax03's Avatar
I usually paint and I've been successful with the paint staying intact for years! It's all about the prep!
Old May 18, 2014 | 07:23 AM
CS_AR's Avatar
Here are a couple of pictures with the refinished pipes on the car. I sure hope the o-rings hold up. The pipes felt solid and I could tell the o-rings were sealing the connections.
Valve cover polishing was still a work in progress when I took a break last night to snap the following picture. More to come with engine details about the coolant crossover pipe.
The original 10mm mounting bolts were changed to use stainless hex cap heads with lock washers in this picture. If possible, I like to use this type of bolt for coolant and fuel connection bolts.
Old Feb 25, 2017 | 01:04 PM
maximatech12's Avatar
Nice but they rust on the inside too! Almost eat through completely!
Old Feb 25, 2017 | 01:45 PM
Notice the metal pits ?
Old Feb 25, 2017 | 05:28 PM
CS_AR's Avatar
In that case, I would order some new ones or find a car in a salvage yard with ones in good condition.
Old Feb 25, 2017 | 06:09 PM
Violator's Avatar
looks like you can get new discharge and suction hoses for ~$20 each online
Old Mar 10, 2017 | 08:55 AM
So what do you do about rust in the system that's built up like small barnacles?
If I loaded a gallon of rust dissolve in the block would it damage the head gaskets?
Old Mar 11, 2017 | 10:39 AM
CS_AR's Avatar
WOW - This is an old thread. I think the pictures were made about this time 3 years ago.
I can see the pits from the picture.
Fortunately, the 99 model (with a 95 model engine) where I refinished the pipes, had under 80,000 miles. I didn't notice any rust on the inside of the pipes. The pipes came with an engine from a local car that had been in a bad rear end collision. I bought the motor and had it installed in the 99 model.
This year, I took the pipes from the 99 model's original engine with under 170,000 miles and refinished them for the 98 model with over 235,000 miles.
There is a 2nd thread on this topic, where I refinished the pipes from the 98 model. Those pipes are some of the worst that I've seen to date. In the time frame for the 98 model project, I discovered soaking metal parts in muriatic acid removes rust in a hurry.
I think the quality of water that is mixed with anti-freeze to make coolant has a lot to do with the formation of rust or barnacles in a cooling system.
The 98 model lived in a part of the state when iron deposits in the water so high that people use water softeners to condition the water for indoor use. The iron content in that area's water will stain plumbing fixtures unless the water is conditioned before use. I could see that in the cooling system when I had it open.
One of my cars, lived for many year in a part of TX that must have had a lot of sulfur or calcium in the water. I found crusty mineral deposits inside its cooling system.
Even though the area where I live has good water that does not require conditioning before use, I like to use a 50/50 mix of distilled water and Xerex G05. After seven years of use on all of my Nissan products, it seems to work.
So here's a picture of the acid bath where I cleaned up some pipes and put them away in my workshop for another project. Naturally some light surface rust has appeared on the freshly cleaned pipes because I didn't prime and refinish. I have an EGR pipe that I will treat sometime later in the year. I have another VQ30 from an I30 that I will be semi-overhauling to have on the shelf in the event I need a replacement engine.
Here's a picture of the pipes that were refinished in this thread almost 3 years later. I am satisfied with how they are holding up. No surface rust, no complaints, and low maintenance.
I see a coolant flush product advertised for removing rust. This seems to be more popular with iron block engines.
If you find one that you think is safe to use on an aluminum engine, you might try it. One thing to note is acid and aluminum do not get along very well.
An aluminum part that is submerged in a muriatic acid bath that is strong enough to remove rust from metal parts, will fizz like an effervescent tablet. You can watch your part turn dark and start to dissolve right before your eyes. So I would use caution with a coolant flush that was designed for iron block engines that contains a lot of acid.
On one aluminum engine car, I used vinegar like the guy in this video. Though I followed it up two or three distilled water flushes to neutralize the vinegar before refilling with Zerex.
Many years ago I would see some coolant flush products shorten the life of water pumps. So I've always been hesitant to use a lot of chemicals to flush a cooling system.
Old Mar 26, 2020 | 06:29 PM
saig's Avatar
Flush.
After looking at this picture, do you want to open engine block drain bolt the next time you flush?
WP pumps coolant through the hole near cylinder #2, around each cylinders, then through opening holes in the head gasket to the upper engine block which houses cam shafts and valves and out the pipes to radiator.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Quickywd01
Sep 21, 2016 09:36 PM
